I don't see this distinction made very much when searching for info on the 3500.
For 04-05 the 3500 (LX9) had a 94 mm bore, 84 mm stroke and did not, AFAIK, have VVT. Did this engine have the large crank pins and forged crank?
I'd call that a Gen III engine. Is that the general concensus?
For '06 the 3500 (LZ4/LZE) uses the same 99mm block with offset bores as the 3900 and has a 76 mm stroke instead of 84 and has large crank pins, forged crank and VVT. This is a Gen IV engine, yes?
