Finally posting my 3400 build
  • IsaacHayes
    replied
    Compression FTW!
    replied
    I'm curious to see what this thing does with 11.5:1 compression... Thats way up there.
  • johnnymossville
    replied
    After it's running I'll post some exhaust clips. The cam is not that big but I hope that it still has a little lope to it. I am going to run duals and I've got a pair of Dynomax Super Turbo muffs for it already, but haven't decided on the tips yet. The dyno will happen asap, but it needs a few miles on it first.
  • 01GPGT
    replied
    i am going to be doing the exact same set up
    are you going to post dyno mumbers? and an exhuast clip?
    replied
    Nice!
    that thing is gonna scream
  • johnnymossville
    replied
    IT IS FINALLY IN THE CAR! The engine is in and now to hook everything up. I'm useing two 3500 front exh. manifolds but I'm going to have to change the cooling fan because the front mani. hits it. Hell, I was worried that the rear mani. wasn't going to fit and it has plenty of room.lol The headers that Fastlane02 on b-stuff is making aren't completed yet ,so I don't have headers. Anyway I've got some pics in the camera and when I get a chance I'll post them. When it's running I'll post some datalogs and get some opinions on the tune. Thanks again for your help Dave.
  • Guest
    Guest replied
    looks like there is bind in that spring.
  • johnnymossville
    replied
    Well, I finally started assembling the engine today and it will be finished tomorrow. I have some pics and I will get more when it's together. I"ll probably post the pics and the final specs Sat. night or Sunday for everyone to see. I've been collecting parts and the car over the eleven months and it's finally coming together. I want to thank Superdave, John (ForcedFirebird), and Ben for all of the help that they have given me. When I get it running I'll probably be needing a little help with the tune, but it should be close thanks to Dave. I'm still on vacation next week so it will be in the car and running, hopefully driveable!
  • torq455
    replied
    agreed. bigger is not always better. too big on the manifolds and you'll lose the scavenging effect from low velocity.
  • IsaacHayes
    replied
    I do think though that you should go with dual 2" or dual 2.25" from the manifolds, into a Y into 2.5" single back. I'm willing to bet you'll loose some power with 3".
  • torq455
    replied
    it has duals. i agree with the single pipe.
  • johnnymossville
    replied
    Originally posted by torq455 View Post
    yeah 3" exhaust is just too big for your power level. has the short length of your car been factored in? a shorter pipe will have less surface area and less flow resistance. my dad's 03 Z06 has 2.5" exhaust the whole way through and he's making ~ 470 HP. If your making over 350 crank HP then 3" would be ok. all in all, i don't think it's really critical to have the "optimal" biggest size.
    Is that a single pipe all the way back, or dauls? I don't see how it's possible to run 470 hp through ONE 2.5" pipe.
    replied
    3" worked well on mine last year, i'll be using the same midpipe this year but with 2 mufflers at the back to get the full flow of the 3" pipe.
    i'm also installing a manual cutout for the track
    Looks like it's all coming together well
    Here is a pic of .549 lift with an empty modified lifter and the comp 26915 springs and stock 3500 seats.
  • torq455
    replied
  • johnnymossville
    replied
    Was actually like 1 7/8" from the factory, it's 2.25 now.
