Originally posted by citr0
View Post
300 crank hp on the 3.4l(boost)?
what is det comp when you put the 3400 heads and pistons in the 3.4 block ?Originally posted by ForcedFirebird View PostYou'll want to change to 3400 pistons. The DIS is controlled the same way the HEI is. I have a pic somewhere of the two ECM wiring if you need.
yes please!
thanks for the help ForcedFirebird..
does anybody know where to buy a rebuilding kit to the 3.4 ?
i have tried ebay, bot no luck...i have tried summit, and all i can find is a gasket set.
