throttle bodies
  • throttle bodies
    i was going thru sum of your old post to come across something about throttle bodies.i have a 1995 grandprix with a 3100v6 and want to go to a bigger throttle body- what year is a direct bolt-on-replacement(late90's3.4 or newer3.4/3400)with few mods?
    Thomas Herring
    A 3400 TB is 56mm vs the 52mm of the 3100. It is basically a direct bolt on. You have have to pull the shaft out and swap them due to the linkages being different, but other than that, it will bolt straight up.
    There are also a few aftermarket things available (only 1 true non-stock modified) that would get you even larger (up to 62mm), but you are looking at more $$ then. You could probably pick up a 3400 TB pretty cheap from a junkyard, ebay, etc...
      so it would be an easy upgrade and what performance would i see with the and what year do i get?
      Thomas Herring
        It would be very easy (IMO). As far as gains, I'm not sure. Don't expect huge gains, and I really doubt you'd even be able to feel a difference, but anytime you can introduce more air into the mix, you will cause improvements.
        If you want, I have a 2000 3400 TB sitting in the garage. I'll measure it to make sure its a 56mm unit. Make me an honest offer (what do you think it would be worth to you), and I will consider it.
          You could also try the 58 mm TB from the minivan/crossover 3400. Of course you'll want to flip flop the linkages.
          Lorenzo
            I'll second that minivan part!!
            Brian
            3400 SFI V6, 4T60e
              smaller one is from a 94 Beretta, larger one is from a 99 Alero..
              Cliff Scott
              89 BerettaGT
              89 Volvo740
              Cliff Scott
              89 BerettaGT
              04 AleroGX
                I beleive L cars and at least early N cars got the 52mmTB. W's and other cars got the 56mm and minvans/crossovers got the 58.
                Lorenzo
                  All 3100's from 94-99 had a 52mm throttle body.
                  ALL 3400's from 96-pressent use a 56mm throttle body.
                  and now i believe that the 3100's with the larger port intakes from 2000+ also use the 56mm?? i cant remember if they also changed up to these as well.. i'll have to measure one at work here someday if i get ambitious enough to pull the air tubing off.
                  Colin
                    throttle bodies
                    what minivan/crossovers got the 58mm throttle bodies?
                    Thomas Herring
                      Re: throttle bodies
                      None. there is no 58mm 3X00 throttle body.
                      Colin
                        Ooopsy my mistake... I see one thing and think another... Yeah the 56mm is the biggest...I know there was one smaller than the regular one(52mm?) that is usually offered on the W cars...I have it in my garage somewhere... It came from a '99 Malibu VIN J 3100, it was really small... the smallest I've ever seen. I know I saw a tb on a corsica and that too was rather smallish. Not that it's worth anything but if I can find the malibu tb I'll measure it...I'm pretty positive I've seen stock tb's for these engines in 3 different sizes.....
                        Lorenzo
                          The only other TB that might be a different size is the funky one on the A-Body cars. With the integrated MAF.
                          Thinking about it now, those probably have some sort of variation of the V6/90 computer controlling them.
                          Cliff Scott
                          89 BerettaGT
                          89 Volvo740
                          Cliff Scott
                          89 BerettaGT
                          04 AleroGX
                            Does anyone know what the stock T/B is for the F-body 3.4's???
                            Carmine
                            1993 Grand Prix SE, 3.1 TB coolant bypass, 180 T-stat, for starters...
                              the F-body 3.4L TB is 52 mm
                              BTW: what is a camaro LS ???????
                              3.4L camaro some goodies
