As some of you know, Im in the midst of a hardcore 3500 build-up. The turbo Im using is capable of 550 rwhp.
(before I continue, some dimen. modifications and parts for the gear heads)
Block "bored over" .020" (from 3.70 to 3.720-3.722)
total de-stroke .128" (from 3.31 to 3.192)
crank pin diam. 2.100 (uses LJ sbc con-rods)
connecting rod 5.850 (original 5.900)
comp hiegth 1.4600
piston to deck +.030"
head-gasket thk .070"-.071" crushed (annealed copper style)
CR 9.6:1 apprx.
3500 steel crank reground, destroked knife-edged and lightened
(attempting to install oil-squirters on all cyl, dont know if it will work)
3900 oil-pump (that is, if it fits)
total displacement- (207 C.U.) true 3.4l
Parts list
port 3500 intake plenum & LIM
ported LX9 heads with "Manley" ss valves and comp cams #122 springs and steel retainers)
Wottech 65mm TB w/ adapter
forged "Wiesco" pistons
Eagle 5.850 "ESP" H-beam rods (bushed) .927 piston pin & .225 crnk-pin bore
s-256 compressor, t-3 stainless housing w/ .69 A.R. & p-trim wheel
JAZ 50mm ss WG
Synchronic BOV
Snow per. meth inj
ARP main and head studs
fiero "stock" iron flywheel (used to have a 7lb fidanza aluminum flywheel. need the extra inertia for hard launching)
Megasquirt 3.57 board w/ MS2 proc. (configured for DIS, on-board boost control, e-85 sensor input for map-switching, anti-lag) running MS2nE code
#65 Low-z injectors
(Final Combo built for 7540rpm max shift-point w/ absolute 8000rpm red-line)
TKO-600 5-speed tranny
Mosure 12-bolt rear-end w/ 3.42 gears and all the "fixins"
The question is, will this motor survive the rated 550hp at the tires without stretching mains or studs.
Id love some feedback.
comp hiegth 1.4600
CR 9.6:1 apprx.
Parts list
JAZ 50mm ss WG
Synchronic BOV
Snow per. meth inj
#65 Low-z injectors
