3400 TB on a 3100
  • 3400 TB on a 3100
    I got an 01 gp with a 3100 i stuck a 3400 TB on it and had a bunch of problems, shifting was bad and it would not down shift at all.
    I thought it was a direct easy swap, some info on whats wrong would be nice,
    I put the3100 back on and it ran fine.
    Is it even worth putting the 3400 TB on it?
    Did you swap your sensors? They are identical minus size, 52mm vs 56mm. If the 3400 had bad sensors, then that is the problem, not the TB.
      No I didnt switch the sensors, I'll give that a try.
      Is it worth putting the larger tb on
        yes it is. very worth it, considering its just removing and replacing the part.
        [SIGPIC]
        12.268@117... 11's to come!
        [url]http://www.youtube.com/watch?v=7ibU1k8UZoo[/url]
        [url]http://www.youtube.com/watch?v=GUqJyopd720[/url]
          Don't the large-port 3100's and 3400's have the same size TB? I thought it was only the older, small-port ones that had 52mm TBs.
          1995 Grand Am SE
            All 3100 are 52mm
              I'd say the TPS on the 3400 one was bad. Swap your 3100 TPS over and it shoudl be good.
              [URL="http://isaachayes.60degreev6.com/"][SIGPIC][/SIGPIC][/URL][SIZE=1][COLOR="RoyalBlue"][/COLOR][URL="http://isaachayes.60degreev6.com/z26/ss-todo.htm"][IMG]http://isaachayes.60degreev6.com/z26/signature1.jpg[/IMG][/url] [COLOR="#FF4000"]New 2010 project (click image)[/COLOR]
              [/SIZE] [SIZE=1]16.0 1/4 mile when stock. Now ???[/SIZE] [SIZE=1][U]
              Original L82 Longblock[/U] with LA1, LX9, LX5 parts
              [/SIZE]
                yep i guess it was, changed the TPS and it runs great, thanks everyone!!!!!
