2.8 Stroker kits!!!!!
  • 2.8 Stroker kits!!!!!
    Check out removed for the best stroker kits, and high performance cam shafts.
    Yeah, not gonna let ARI get free advertising on here...
      lmao
        Fail at relabeling factory parts and fail at spam
        87 3.4 4x4 blazer
          you removed the link from the message body, but it still remains in the "tag" :P
            Yeah, not gonna let get free advertising on here...
              I was just posting it as reference, they have supplied good parts for me. By the way will a 3800 throttle body bolt up on a 3100?
                No, and why would you want to use a 3800 TB? Even if the bolt holes lined up which the don't, it uses a rubber O-ring to seal to the factory plastic upper intake on the 3800 and the IAC is in a different spot, so that wouldn't work. Plus it's longer and has a venturi style MAF built into it.
                iirc the early 3100's came with a 52mm TB? Not sure if the later 3100's with the large port intake mani's from the 3400 came with the larger TB or not, but the 3400 came with a 56mm TB so you could probably use that if you were looking for a cheap oem upgrade. Otherwise you can get 62mm or 65mm from WOT tech.
                '97 Grand Prix GT 3800 (sold)
                Gotta love boost!
                  Thanks for the information.
                  Yeah I will use a 3.4 , like wise the the whole intake. Since it has better, flow.
                    They just supplied you with factory GM parts at a high price and you bought it thinking it was a real stroker kit. GM done the "stroker" when they went from a 2.8 to a 3.1 so the parts were already out there and normally a lot cheaper than the fake stroker kit.
                    87 3.4 4x4 blazer
                      I have a stroker crank in my garage. Anyone want to buy it?
                        I have about 3 3.4 de-stroked cranks up for sale
                        87 3.4 4x4 blazer
                          haha, for real!
                          Andy
                          fastest 1/8: 10.19@ 67.17
                          fastest 1/4: 16.16@ 82.70
