Since there isn't much of a choice in aftermarket camshafts has anyone experimented with Advancing or Retarding the Factory Roller Camshaft?
Camshaft Timing 3.1/3.4
there are tons of aftermarket cams for the 3x00 engines, and endless possibilities of custom grinds.
yah, roller cams aren't cheap like flat tappet cams.
desktop dyno showed a few HP gain by retarding the stock cam by 4 degrees, i'd wait to see if Ben chimes in though. His program is much more accurate.
You could offset the alignment of the timing set by a gear, but not sure by how much that would adjust your timing. Probably more than you would want to...-Brad-
You could have another keyway cut in the crank gear...
