1991 chevy beretta 3.1mpfi to 3.4sfi swap
tips? did you have any difficulties? what car did u get the 3.4 out of(id like to get one i dont have to replace the timing chain on)? why are you taking it apart this summer?
youve already done the 3400 swap in a beretta robert? how did it go can you give me any tips? i looked in ur garage and it says u ahve a 89 with a 3.4..
well if you ever need a 3400 top end heads intakes t/b.Let me know mine is coming off this summer.
1999 grandams had 3400sfi motors we used to have one.. ive got 1000$ to play with for this i cant spend a penny over tho... im looking at the 700 ish mark for were ill be that gives me 300 for parts ive forgin or parts i break ect..
are you doing a hybrid swap in the end? i think a 99 venture 3400 would be the same as a 2000+ motor aside the chain and upper intake with the EGR. of course it will be a PITA to pull as it comes out the bottom easiest. And you will have to change the timing chain. I dont recall when the GA's started coming with 3400's, i think it was 2000? anyways, i hope it works out for you getting the 3400 for $140 leaves alot more money for the budget or and a rebuild.
well thats ifff i can find one at pull and save.. 1999/2000 is JUST now starting to appear in pull and save.. usualy that stuff goes to spaldsings who charges 700 for same engine... and yes its only 140 but its a self serve yard so
Wow 140 for the whole motor.I spent 250 for 3500 heads and a LIM but they have 20xxx miles on them.The trans takes 2 1/2 quarts i would use GM Synchromesh.Less wear and better with high temp i would check it to a few days after.
thanks for this i just remplaced my ball joints... hate those rivits... now i wont trash some new joints!
I've also seen an air hammer work this same way, but I bet it doesn't release as much pent up aggression with an air hammer either.Originally posted by bob442 View Postdont use a ball joint splitter, just hit the outside of the knuckle where the ball joint goes in it. othwise, you eill damage the ball joint.
depends what its from right? if its from a w body or a van, you will have to change it. its no big deal.
i Though with the timing cover all you had to do was grind something off of it not change it?
its extremely easy to get that bolt with a 3 foot extension, you will need to get a 1/2 drive extension though, otherwise a 3/8's will just twist and twist and twist. you could even make one if you cant find one for under 20$
that mount that i put a picture up of was drilled off of the car from the spot welds. when you get your 3400, you will need to replace the timing cover i believe with a 94-96 beretta timing cover, or second gen grand am (94-97?) most likely grab the timing cover from the car your grabbing all the other parts from. Just get a saw and cut off the frame rail and strut tower. And grab all the accessories that your other motor wont come with. thats your best bet. Or hey, see if the scrap yards have a core charge, if so, grab the timing cover from a blow motor, or put an add up in the buysell section. John or Ben might have some, you never know.
Trans oil should be Gm syncromesh, or i think someone else makes it, i think its 4 liters. possibly 2 but you'll have to check. If you have to pull the timing cover, which you probably will, i would suggest getting a new timing chain if you plan to put lots of miles on it before you pull it to modify the internals. get a 99 pre 3400 timing chain, just a cheap one, but if you want to spend the money a GM is $150
And your over paying for the exhaust. You will need to get a welder for the mount bracket. Also, you will need a very thin wide chisle, and it would be a good idea to get some self centering 5/16 drill bits, the end looks like there is a smaller sized drill bit sticking out, and use some wd40 to keep the bit cool otherwise it will burn up and go dull, I've used one bit on over 200 spot welds by keeping it nice and cool all the time while drilling. When there 15$ a piece, its worth it to waste a 3$ can of wd40.
IDC about the grammer, i just spewed this all out haha
Bob
Ok so i figured it would be smart to make a complete list of all parts/prices needed for this
Engine:
3400 motor $140
Chip $50
G1 adapter $35
Oil Castrol edge or moble 1? $20
Oilfilter Fram gold $10
Sparkplugs bosch platnum +4? $30
Sparkplug wires Napa premium $45
Beretta Motor upper motor mount $Unknown
Coolant use DEX or GREEN? $10 - 20
custom exhaust down pipe Quoted $120
Engine Total: $470+
Transmission:
Getrag 282 $55
Driverside axle $19
Passanger axle $19
Gear oil? What kind? $Unknown
Clutch/break pedle assembly $10
Shifter $10
shifter cables $20
Transmission Total: $133+
Total: $603+
I know i forgot parts so im sure im looking at more like 700 - 750
Considering some other stuff...
1. Ac Delete? Anyone know were to get one? ive already cut out most of the ac lines and removed the canister only pump is left now.
2. Is it better to use the newer style mount? ive seen custom brackets for sale to use the olderstyle like mine?
the reason i ask about mount is idk what to do with the coolant overflow or wiperfluid if i use never stlye
3. Idealy ill find a transmission with a brand new clutch :P yea right !! anyways i know NOTHING about clutchs other then how to use one so some advice would be nice!
Im trying to make this super detailed so if theres ANYTHING i missed let me know
