he's building a hybrid with pistons and cam (and the rest is still undecided lol just joking rob) he said he used a grand am wiring harness to run the motor. i could have swarn his was a 95 though, so he has all the mounts. Are you going to have access to a welder Cody? you will need for that upper mount onthe passenger side.
you will need a timing cover that looks like this:
you know what, check out this whole page:
i guess you could use your current mounts for the motor, but from what i gather, they changed the design for good reason. the top mount blows out on the newer design mostly because of the lower passenger mount being a stamped POS
this is from a Q4, but the first few pictures are the same mounts as what was on a 3.1
I've seen guys blow through the from passenger side mount too many times like you have, so if someone else wants to jump in here and offer a solution aside upgrading the mounts, please do.
