So gm decides that waste spark is cool. basically it means you use 3 coils on the 660s to fire 6 cyls. Basically they use use 3 fire signals. Meaning the waste spark always fires the other coil because its connected to the module.
So you can *possibly wire up some LS coils to do the same thing. But you have to pair the trigger wiring for the coils up like GM does with their coils. Like companion cyls. It will statically fire 1 and 4 each time, but its almost the same as waste spark, this way you can you the LS coils instead of that lame module as long as the PCM is what is controlling the fire signal.
Any arguements?
Any arguements?
