I'm looking for bigger injectors for my engine. one day i will put a turbo on it. i was wondering of a part number i would need to put bigger injectors on my car. would i require a pcm that supports it?? i probably would put the bigger injectors on first and later turbo it.
3100 Injector mod
Bigger injectors are worthless without a PCM programmed for them.-Brad-
dhp will not touch your obd 1.5 pcm at this time
and if you are able to get a turbo going, get the 42.5# Lucus 009's from www.zzperformance.com and make sure to get your pcm tuned somehow otherwise just run very low boost, like 5 psi on stock injectors
