Ok so that isn't exciting...its just sitting there:P
http://wot-tech.com/Dyno/dyno%2012-14-12%20001.jpg
Link to a huge pic of the dyno sheet. So I want to discuss this because that dip near the end is odd. It got worse with each run even when I changed fuel and spark (to which we found where it likes the spark just fine 2 degrees less than before KR). Its about 10 seconds in so I want to go through the code and see if there is anything special about that time frame, or roughly 4800 RPM
The car has to run the 28# injectors. We hit 73% duty cycle on these runs, and even though we am commanding 9.3:1, its running 12.3ish (that is where its happiest, not mid or high 12s). Absurd, but the normal driving and idle are pretty damn good and the wideband reads 14.7-15.2 most of the time, which looks fine to me. It doesn't matter what is commanded, only what is real, so I am happy with the results even though it puts our "Before" numbers much higher than the normal 143 WHP results I see for these cars. More to come, just a matter of figuring out what we want to do first. Port work is simple...headers would be nice. Also would like to compare 56mm vs 65mm on the ported set if we can get that setup.
