Well I sold my Grand Prix,after it are 5 transmissions,and inherited a Buick century in great shape..
It sadly runs nothing at all like my GP did
I am looking to upgrade the size of the throttle body,This is a 3400,and for some reason it has a 52mm tb on it,I took it off,and measured,I was kind of shocked cause,I thought 2000+ had 56mm on them..
I would like to put a 56mm or 62mm on the damn thing,I am going to the bone yard in the morning.. I've searched on here,and google alot,I think there needs to be a stick Tb thread..
What cars might I be looking at in the yard that would have either of these two options?
My other issue is line pressure on the transmission,I would like to be able to adjust the voltage to the epc solenoid,but cant find the correct wiring diagram for that trans,the ones I have found the connector is the same,but the colors/pin codes dont match my car for shit..
Those are my two major concerns right now,bugs the hell out of my how gm programmed these damn century's I mean we wouldn't want granny peeling tires,or feeling any torque,lol..
I tried to put a 00' GP ecm in,yeah... the part numbers and all matched,but I am guessing passkey II or w/e wouldn't allow it to start,I damn sure am not against changing the ecm out either,Just need the slug to run a bit better..
EDIT: Found someone saying a stock GA is 58mm,any of you guys confirm?
Thanks
Russ
Thanks
Russ
