Overall dimensions are the same between the 2 generations.
The exhaust port spacing is identical, bolts are the same size/location (I've used Gen 2 logs on gen 3 heads). The exhaust port shape is different (D vs O).
Intake ports have different shapes but are in a similar location. The LIM bolts are all in the same place for a Gen 3 VS Gen 2, but there is no way the ports will line up. Coolant ports are the same. Combustion chambers are smaller but the same design, valves are at the same angle but the intake valves are bigger in the Gen 3 heads IIRC.
Here are some pictures..
This is the top side of a ported 3500 LIM vs an un-ported Gen 2 LIM:
Here you can see the exhaust ports on a Gen 2 head:
VS Gen 3:
I'll dig up some intake port pictures... I know I have some. If not i've got gaskets from both generations on the wall so it's easy enough to get an idea of port shapes from that.
VS Gen 3:
