just got finished rebuilding 3400 for 92 corsica .little thumper cam from ben ,ported upper and lower ,heads have ls spings ,seats and seals from ben ,3 angle vavle job,65 mm tb, WOT-TECH swap chip ,22.5 injectors ,2 1/2 " exhaust .car runs and revs great in park but when driven it worse than stock 2.8 .my question is will stock fuel pump keep up with this engine.
all bark no bite
its 55psi, fuel pressure seeem to jump around a little when reving ,the only code was iat ,only because it wasn't hook up ,ks is from the 3.1 engine ,crazy thing is this the second 3400 engine in this car the first one was stock, put it in a 2000 ga runs great ,did the new engine for the corsica ,it slower than the stock3400 and 3.1. I also changed tranny and converter now it has 2700 stall and 306 fd.
Any sort of logs from driving to see what the ECU is reporting?
If its not a custom tune for those mods, then its not going to run very well. The 3400 swap chip isn't for a little thumper cam. Your fueling is based on vacuum, which is significantly different than the stock cam.Last edited by SappySE107; 09-17-2014, 09:05 AM.Ben
don't have the equipment to data logg just yet ,will have by next week though .car run fine under normal driving ,its just at wot .just did 3400 swap and 3.33 fd on 96 z26 car runs strong ,just want to straighten things out before the engine build on this car is finished witch has already began
