Both the I4 and 60degree V6 T5 have the same bolt pattern, so it will fit the 4 cylinder bellhousing. The V8 T5 is different, in the mounting ears and also the input shaft, so it's not really a viable option anyway.
3900 rwd
Quick answers:
Yes, you can use the Ford pattern T5 (which is a WC box most likely, just like the 93+ S10)
Yes, you will need to use the ford clutch hub. Getting the hub changed by the clutch company has never been a problem for me. Just CALL and talk to the clutch company and ask.
Yes, you need the bellhousing for the 93+ 4-cylinder and you'll still need to touch up the starter pocket-it's not quite a perfect fit.
The T5 transmission in both Non-World Class and World Class forms was rated for 295ft-lbs input torque, and while parts do not interchange for the most part the WC boxes were not upgraded in strength, but instead in shift feel and shift linkage durability.
The 2.95 1st gear is "stronger" than the 4.03 first gear from 4-cylinder trucks and the 3.76 from the V6 trucks, but that isn't where you're going to get breakage in a T5, *usually*. Usually you'll get breakage by overshifting the box and breaking off the shift fork, which then lodges bits in the gears and THEN the box explodes. It's fun, you should all try it at least once.
Then, after the overshifted box, the input shaft gear normally gives up before 1st gear does.
I have a b&m shifter...they have a stopper built in. The parts I'm using aren't the best, I know but chevette's only weigh 2000lbs and the 3900 probably isn't gonna exceed the 300lbs so everything should be okay. I'm also gonna use a 7.5 s10, they're crap to but lots of parts out there and should be okay with everything else
Sent from my HTC One M9 using Tapatalk
You think the 3900 would like this Cam?https://wot-tech.com/shop/stage-3-ro...m-package.html
lift and duration specs aren't given. perhaps an email can get you that info. it does state that the spring seats will need to be machined. of course thats not sure if hte 3900 heads will need that work too. If so then the heads have to come off. I would check with Ben at the store.
if the heads have to come off for machining, and thats not something you want then you can always go with the stage 2, or have a custom grind done.
remember the 3.9 supposedly has 1.7 rockers instead of 1.6 which will affect overall lift numbers. try to get lobe lift numbers if possible and then do the math
The rocker ratio is 1.7:1
The ports flow on par with the early LS cathedral ports (no need for porting)
The cam bearing journal is 2.025" OD vs. 1.869 for the earlier engines, so some have installed cam bearing spacers to allow the use of previous generation camshafts.
I'm curious what you find for a cam for your LZ9. Delta turned me down for doing a regrind for me because it's a hollow assembled camshaft. Since then, I've found Joseph Upson's cam card from his LZ9 regrind they performed in August 2007. Maybe they decided they wouldn't do another after his.
I also have a spare set of spacers that I can part with if you need them and I'm about 40mins from you.1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
I've been contemplating starting my own thread with my cam questions, but this might be applicable for the OP and I have the attention of some knowledgeable guys, so I'll ask here first:
1. Is there a difference in base circle diameter among the factory 60v6 cams? I've noticed that the LZ4/9 shares a common .2727" lobe lift with some early 60v6's, so I'm hoping GM was lazy here and didn't actually change the lobes when they went to the larger cam journal.
2. Can I use a 60v6 flat tappet cam as a regrind core for an LZ4/9? They're much more plentiful and much cheaper than roller cams after a brief search.
3. How about shrink fitting steel rings (~.078" wall thickness) onto the (disposable) early gen cam journals and then turning to 2.025" and polishing on a lathe with a live center?
If I sound extremely cheap, it's because I'm trying to explore the potential of this engine for the GRM $201X challenge and maybe even Lemons/Chumpcar. I already scored a deal on LS6 valve springs and my cam idea right now is to replicate the GMPP LS1 ASA cam (226/236, .525/.525, 110 LSA).
and the regular one you were talking about, starter is the wrong side
