Blue vs Red Box, Durabond Cam Bearings
  • Blue vs Red Box, Durabond Cam Bearings
    While the proper bearing material and bearing selection are important factors, the right alignment of the bearing in the cam tunnel is also critical.
    I have been using the red box exclusively. but the blue box should be good for most 60V6 owners building an engine. They claim 400# open pressure should be when you make the jump. I like the tighter tolerances for the VVT delete cam bearing spacers, but there is definitely a use case for the blue box. Finally found this article so wanted to share.
