(IMO-the 3400 would stop making power after 6.5Krpm anyway...if it would be a 2800 hybrid..then I say go for it).
Weakest component on a 3400 block?
Re: RE: Re: Weakest component on a 3400 block?
Don't you shift higher then 7500?Originally posted by TurboZ24The 5-speed will not shift at high rpm. The auto's are rated at a max input shaft speed of 6200 rpm.Rob
\'91 Chevrolet Beretta GT 3400 5 speed
R/t .506
60\' 2.195
330\' 6.138
1/8 9.390 @ 76.48
1000\' 12.183
1/4 14.553 @ 94.01
Http://www.domesticcrew.com/660
He installed a cam in eric99gt's (SN on GAGT) car, who stated that he had heads from you. And here is Milzy's comment...
"i hate to be negative about someone else's product, but his heads are quite restrictive on the exhaust. i didn't have time to get them flowed, but i know for a fact ours flow a lot more."
That was on page 29 of the 3x00 Cam thread. I think he might have said something else as well, I just didn't go digging anymore.-Brad-
Yeah, and that's why I say it does't shift at that rpm. The 1/2 shift in both trannies I've had just doens't engage or gate until the engine spins down. Slows us down at the track, waiting on that 1/2.
Rollers valve train is a must for every ounce of HP. Solid or hydrolic? Well depends on your engine configuration and cam profile. Solids are resoved for high rpm(6K+rpm) since they don't pump up like hydrolic but they need ajusting every now and then if flat tappet or for fine tunning. Hydrolic are for lower rpm power (under 6Krpm) and street use.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
True i'm shifting at 6500 (actually closer to 6600), but with the tranny slip (damn automatics), I'm hitting 6800. I've set my limiters at 7200 (fuel & spark).Originally posted by 91BerettaGTthe guy with the grand am only revved to 6500 and pulled a 14.1 with a 2.2 60 footer and that was in like 80 degree weather. (stage 2 cam/heads/ported intake manifolds TB and headers.) His motor in my car would give colin a run for his money
If you look at my dyno graph, the power peaks at around 6000, but doesn't drop off. stays pretty flat. I had the guy running the dyno to stop at 7000 and the power didn't drop off at all.
The only reason I'm shifting so high is for the gear change. The power starts to climb at around 4300 rpm, so when i'm in the next gear, I want to be in the power band. Generally I'm starting my next gear at around 4500.
I'm still running the stock pushrods and the bottom end is still stock. So is the tranny.
IMHO, the tranny is going to be the first thing to go. Milzy is coming up with a 4T65E conversion kit (unconfirmed). Hope this works out!!!!
Also a few things to correct in your post. That run was made in 90 degree weather (not 80) and the mod list is missing one very important piece. Alot of tuning was done to get those times (HPTuners).... I still don't have it right
I have probably made it worse since I don't know what i'm doing, but can't afford to pay someone!!
Sorry if I went off topic.
BWAHAHAHAHAHAHAHAHAhahahahaOriginally posted by 91BerettaGTI've also been talking to 1QUICKHATCH. Whom i'd rather buy from but I want at the same time nothing but the best for my car, so if he can get me what milzy is offering, cheaper, or same price, I would get it from him.
Sorry, I had to laugh at that comment.
I've seen some of Scotts "ported" heads, and they are not, they have been cleaned up, however.
Anyway, I've seen what Colin can do, from time slips and comments from some of his customers. Colin is the man, when it comes to 60° (pushrod) porting, along with experimentation of valvetrain and a few other projects.
ok, you have seen ONE set of mild heads that I have done for chris because you assembled his engine 2 years ago. I am not saying that I am the greatest ever but I do good work and I know what works on these heads from the countless hours of flow bench testing that I have done and from my customers using the heads on their cars!Originally posted by The_RavenBWAHAHAHAHAHAHAHAHAhahahahaOriginally posted by 91BerettaGTI've also been talking to 1QUICKHATCH. Whom i'd rather buy from but I want at the same time nothing but the best for my car, so if he can get me what milzy is offering, cheaper, or same price, I would get it from him.
just for the record if any one is wondering, Mr rook has a personal grudge against me for some reason (think its because I didn't buy his 3x00 mount, but only cause it would not work for my application...) so he tries to cut me up and flame me any chance he gets.1999 Olds Alero 2.4 to 3500 swap (running). totaled by a honda
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
You're such an ass raven.Originally posted by The_RavenBWAHAHAHAHAHAHAHAHAhahahahaOriginally posted by 91BerettaGTI've also been talking to 1QUICKHATCH. Whom i'd rather buy from but I want at the same time nothing but the best for my car, so if he can get me what milzy is offering, cheaper, or same price, I would get it from him.
You can't base your opinion on ONE set of heads done a long time ago. Plus...you are biased cause you don't like Scott for some reason.
Anyway... Scott has since done a great job for me (proof is in the times) and for Dan (Z24dawg...proof is in the times there too)
I'm sure Colin can make some decent heads...the comment that that Milzy character made could be BS...could be true. The only feedback Scott has gotten is good feedback.
Dan was running 15.1's all day on a decent night...and the track was STICKY! Then he threw on Scotts Powershop Heads...ran a 14.3
I'm gonna go hunting for a 3400 top end for Scott to port for my GAGT.
I sold a 3400 to a guy with the screen name milzyz off of one of those grand am forums. He lives up near Dayton, ohio or atleast has a shop there thats were I dropped the engine off to. He said he was using the engine as a test engine for testing different camshaft regrinds I believe, seemed like a nice guy.Opinions are like Assholes,......Everybody has one!
Yeah mike is a good guy, Ive known him for a few years. For the most part hes done alot of 3800 and L67 stuff and has been getting more into the 60v6 world in the past year. I know he has alot of research into what he has done and a few cars installed. The S2 Heads and cam have put out 250 on the dyno (not sure if thats crank or wheel, prob crank)
As far as how it compares to other people's stuff Im really not sure, all ive seen so far are flow numbers and a couple dyno charts. Im looking into doing a ported topend, new valve train and a more agressive cam myself now that I have completed my ODBII upgrade so Im curious to know what is out there as far as who does porting and has cams available.
1995 Monte Carlo LS
3400 SFI 60v6
Crank. I'm ~204 at the wheels. With some tuning help and cooler weather (dyno was done at 99*F, 114*F IAT's, 2% adjustment==> 4hp) that might be a little better.Originally posted by ManitcorYeah mike is a good guy, Ive known him for a few years. For the most part hes done alot of 3800 and L67 stuff and has been getting more into the 60v6 world in the past year. I know he has alot of research into what he has done and a few cars installed. The S2 Heads and cam have put out 250 on the dyno (not sure if thats crank or wheel, prob crank)
