who knows, GM has been known for stranger things
Installed the 3500 manifold
i picked up the 3500 plenum for 80 bux on car-parts.com what i did was tell them that i could get a brand new 1 from GM for 120 and they dropped it!
						[SIGPIC]
12.268@117... 11's to come!
Adapter, 3400 gaskets, vacuum line setup redone for the stock MAP or an adapter to use the 3500 MAP sensor. TB arm ground down to clear the fuel pressure regulator, either a bracket adapter for the DIS to plenum mounts or let it hang off the bottom 2, charcoal cannister purge mount changed or let it hang, and block off the 3500 IAC passage or tap/thread a nipple in there to use for a vacuum source.
Im still working on a kit to make this swap as simple as possible.Ben
Interesting. It is like they removed it from the catalog. I had been waiting for mine for about two weeks since it was in a "Special Order" status. Mine should be delivered tomorrow.Originally posted by xtremesunfireyou cant even get it anymore at gmpartsdirect.com unless there is a different part number for it
Maybe there was a part Number change? The UIM I got today has a different part number on the casting: 12598959
Looks like a 3500 plenum to me... Will post pictures soon.
I highlighted the new casting number with a sharpie in the last image:Originally posted by tejohnsonMaybe there was a part Number change? The UIM I got today has a different part number on the casting: 12598959
I ordered mine a while back and had it shipped to ben for porting. According to the shipper status it was delievered.Originally posted by xtremesunfireyou cant even get it anymore at gmpartsdirect.com unless there is a different part number for it
Hey Ben, did it look right?
1995 Monte Carlo LS
3400 SFI 60v6
Sure, I just got mine today, ordred it back on ~Feb 20th. The issue is, now it looks like new orders can't be made...
