While driving my MSD DIS 4 seemed to just die on me. The engine started to run rough it let out a backfire and quit. I installed the jumper to bypass the ignition box and the car started and ran perfect.
The car is a 1990 Chevrolet Cavalier with a 3.1L V6 with DIS wastespark ignition. The box has run perfect for a few years now. When I try and crank the car with the box plugged in the car will constantly crank but will never fire. My spark tester will not show even the faintest spark. I do get a flashing LED that flashes at a constant rate on the box after I have cranked the car over. I have already checked the battery voltage and it is a healthy 13V. I also checked all my coil pack wires and they are not grounding out. When I installed the system everything was soldered and covered in shrink tube. I do not think it is wiring with the coil packs. First of all it has run fine for a couple years now and second when I bypass the ignition box it runs like normal.
Are there any tests I can do on the ignitioin box to see if it still functions? Or does this sound like an internal failure of the box?
