Project:Boosted Hybrid Z24--Heads on engine
  • Project:Boosted Hybrid Z24--Heads on engine
    i am asse,bling my hybrid motor and its comeing along real nice just got done porting my 00' heads and added ls6 springs
    Pretty sweet! Have any problems? What did you end up using and how much was it?
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
      naa no problems very simple,used ls1 shims and had to grind away so they'd fit,and 91 valve seals worked well. hmm the springs were 70,the shims were 30,seals were i think 15-20. hm so wow i spent a good amount there plus headgaskets.
      i got the heads bolted down yesterday i'll try and snap some more pics when the battery is charged
        Looks good man! Damn 2000+ heads! After the first 2 the gridning when really quick for me.
        I did a how to over on grandamgt.com
        2006 G6 GTP MT6
        Vector Motorsports ECU
        Classic Performance 2.5 Inch Exhaust
        v6h.o. Downpipe
        Custom Intake
          http://www.grandamgt.com/forum/showt...ht=LS6+springs
          I definitly read that how to very helpful i must say, everythings straight foward. yeah grinding the first one i was like damn this is gonna take forever but it really only took a lil over 45mins
            Didn't someone find shims from a different manufacturer that fit without grinding? You should have got those. Since they changed the valve guide diameter in mid-2000 that's the reason the LS1 shims won't slide right on the later heads. IIRC the larger valve guide also causes some issues with the 3.1L valve seals not sealing correctly, like they stretch out too much or something and let too much oil thru? I remember reading about it here anyway. You should have used chrysler 318 valve seals. There's a part number someone supplied in another thread on here about using the LS valve springs.
            '97 Grand Prix GT 3800 (sold)
            Gotta love boost!
              ass bling huh? i duno bout that one
              those heads are lookin good though
                lol assembling*
                it wasn't hard grinding the shims, and i was told the 3.1 seals will be fine
                  isn't she so hot? almost wanna hump it imp:
                    If it has the larger valve guides you WILL want to change the valve seals as well. I have a 3.1 valve seals on my heads (2000 Grand Am GT) and they leak. Even though they look like they won't. Believe me get the 318 seals and install them before doing anything else. I hate my car when I start it up cause I get a little puff of smoke everytime. That only comes from one place, valve seals.
                    Your local OBDII moderator
                    2000 Grand Am GT w/ WOT parts
                      I've talked to countless people on different boards and they said i'm good to go.
                      if they smoke no biggie i can change em
                        Be easier to change them now. Yes, go with the 318 seals!
                        Andy
                          your starting to really worry me
                            pshh its a figure of speech
                              its lookin pretty good
