I was directed to this site for information about swapping a 3400 plenum with a 3500 one. I've been searching around the forum and have seen threads mentioning this, but they have been kind of vague. Can someone tell me what swapping the plenum involves, and what sort of gains I could expect? If not, can you point me to a thread that discusses this in length? Thanks!
3500 plenum on a 3400
Within 3 weeks I will have a picture walkthrough and a list of what you need. I will have adapters to use either your stock throttlebody or one that I sell on the store if you want to upgrade that at the same time. There will be dyno results as well for the plenum (ported) that I sell but you will get a decent idea what a stocker would do. Not trying to push my stuff, but I would definetly consider porting it yourself or having someone else port it as the ports are a lot smaller than they should be from the factory. Not hard to do:P
For now, I know you will need to use the MAP sensor off the 3500 (might be the same as what you already have?), grind a bit on the TB neck to clear the fuel pressure regulator, and seal up the IAC port on the 3500 or add a nipple to it for another vacuum line.
v6ho and gpse3400 have both done this swap, and possibly others as well. You could try domesticrew.com as well but a lot of those guys are on this site too so either way we will get it all covered
Welcome to the site!Ben
not to sidetrack, but could you swap a complete 3500 top end onto a gen 2 block? Probably still have to use 3400 timing cover and ps pump though rather than 3500 pieces.98 camaro swapping in lz9 th400 setup
LZ9 specs: (Subject to Change work in progress)
4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
hmmm now only to find a dead 3500 engine (spun bearing/thrown rod).98 camaro swapping in lz9 th400 setup
Thanks for the info. I'll be looking forward to your post. I know my way around an engine, but am way less experienced in a lot of the stuff I've been reading around here. This site is much more technical than the one I usually visit. I guess you can say I'm a newb when it comes to anything that doesn't just bolt on heh. Now that I've explained how newbish I am, can someone explain why the 3500 plenum is better than the stock 3400?
There are no runners in the 3500 plenum, the area inside the plenum is larger, and the TB mount runs like a tube to the middle of the plenum to help give equal distribution to all cylinders. When you change the runner length, you change the powerband to higher RPM. However, it seems that their design doesn't exactly hurt the low end, though the dyno will show us whats going on for sure. Stock, the 3500 plenum flows worse than the 3400 plenum, but because its got a larger plenum area, the ability to run up to 65mm (maybe 66) without modification, and the transition area from plenum area to runner is more like a ram air setup, it still has given people more power. Thats why I say to port it, cause the flow then goes higher than the 3400 plenum plus you get all the other benefits.Ben
How much for one of those stock 3500 UIM?Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
According to the storeOriginally posted by torq455How much for one of those stock 3500 UIM?
$50 for the porting and $150 for the core.2000 Grand Am GT
2011 Chevy Impala
Midnightriderz has completed the 3500 plenum swap, he used a 4.3 TB from a late model CPI equipped S-10.
I believe he's also on here.
Yeah, there are LS6's out there making over 550 hp+ and still using the stock 75mm TB.Andy
man, every1 always forgets about me...
lol
[SIGPIC]
12.268@117... 11's to come!
