To start off, I've been planning an na build on my 3.1 for pretty much ever, and now I'm ready to buy parts and get busy. I've talked with Ben about it, and here's what I'm set on. 272 cam, heads worked on by Ben, full valvetrain upgrade, .030 over, 11:1 compression, ported manifolds with 60mm tb, headers, 2.5" mandrel... to keep it semi short.
First of all, I've been hunting around for pistons for awhile, and I'm thinking JBP has my answer with their Sealed Power Hypereutic pistons. I'm planning on going .030 over, and I want to run 11:1 compression. These pistons seem like a good deal, and since I'm not planning on boost, maybe just a 50 shot if I want to go over the top. Hypereutics fit the bill pretty good. I guess on this one I'm mostly wondering about JBPs customer relations lately.
They've also got "Sportman Rods" that I was wondering if anybody knew anything about. I doubt I'll get them, as I plan on having mine shot peened, or polished, with some ARP bolts. It seems like they have a lot of stuff that I've been looking around for. But knowing how JBP tends to price stuff, I'm obviously led to believe that most of it can be had elsewhere for cheaper.
Then there's also this crank, I don't know if it's anything more than a stock 3.1 crank. http://www.jbodyperformance.com/new/...catName=JP0101 But it doesn't seem like too bad of a deal for $216 for a new crank regardless.
The big plan with this engine is to rev high to work with the 272, and the high compression for the 272, and to move a lot of air in, and a lot of air out.
I've also wondered about a lot of other stuff, like phenolic spacers to keep the low end up, with the 272. But I don't really know a lot of the actual theory behind it. If it would actually hurt the top end more having longer runners, shift the power band low and do more harm than good with the cam selection. I obviously do realize the downfall is the manifolds, mine are ported pretty good. But there is room for improvement - size difference: http://kflo.berettaspeed.com/port_size.jpg
I had them done professionally, the upper and lower are port matched, and the plenum inlet is matched to my "59mm" rsm tb. I plan on getting the 60mm unit from mrzperformance, and reporting the inlet to match it.
I've also thought about making a frankentstein intake manifold too. Because the upper is going to be the bottle neck in the system. Maybe making a prototype with a larger upper plenum area above the runners, and experimenting with some veins to direct air flow potentially? I've hesitated asking about some of this stuff for awhile. But, you guys are the experts. Any comments, or advice other than swap for a 3rd gen/3rd gen parts are welcome and wanted.
