I have a 3.4 that Im swapping the 3400 top end to and I want to which cams can be used with the stock 00' + 3400 valve springs, or do I need to upgrade the springs no matter what?
cam choices
You should upgrade the springs. The flat tappet cams call for some pretty stiff springs if I remember correctly. That is, any cam worth installing anyway. I take it this is an iron head engine you are putting the aluminum heads and intakes on? Any other mods to the motor?Ben
Crane and Comp sell straight springs for the 660 but I would rather use the beehive springs. They are a much better spring. Use LS6 springs or the Comp springs.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
