When did the FWD go roller?
  • When did the FWD go roller?
    I'm trying to find out - did any 60 degree V6 get a roller cam/lifter combo? What years, in which engines?
    Thanks!
    3.1L \'88 Camaro - 16G @ 9.5psi
    222/291 @ wheels
    T61 on the way!
    They started roller cam and lifters in 94 with the 3100. Any 660 after 94 has a roller cam
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
      Ok, silly question... how will I know if an engine is a '3100' vs just a FWD 3.1? The intake and everything is still there.... A buddy of mine has a '95 (I think) 3.1 Grand Am that got wrecked that I might be able to score the engine for... If it's a roller cam design, I'll jump all over that.
      222/291 @ wheels
      T61 on the way!
        The 3100 and 3400 engines say "3100 SFI" and "3400 SFI" on the top of the intake manifold. A '95 grand am gt would have a 3100 engine in it.
        '97 Grand Prix GT 3800 (sold)
        Gotta love boost!
          Ok, thanks... Now to find specs on the 3100
          222/291 @ wheels
          T61 on the way!
            Another quick question - the cam wouldn't have the distributor gear I need, I'm sure... so a custom camshaft would be needed in a RWD 3.1 application?
            222/291 @ wheels
            T61 on the way!
              It does have the distributor gear on it to drive the oil pump. They kept the design even to the present pushrod 60V6 engines.
                There is a gear on the camshaft since the oil pump is driven from the cam. However I seem to recall reading something about the roller camshaft and lifters not working well in the older blocks... perhaps something about oiling? Someone enlighten us!
                60v6's original Jon M.
                  Yes, no kidding... I'd love to build a roller RWD 3.1
                  222/291 @ wheels
                  T61 on the way!
                    Nope hyd roller lifters will not work in a RWD block. They were never designed to support them. The technical explination was shown to me before but I dont know where it went.
                      Just change the entire engine and use the 3100. Better anyway. When they went to distributorless ignition systems I believe they originally just sealed the hole with a freeze plug, so you could probably take it out and add your distributor. I'm just guessing though.
                      Gotta love boost!
                        What about the starter being on the other side though?
                          No they put in an oil pump drive shaft. It fits just like a distributor but with no top on it. Also putting a FWD block in a RWD vehicle would be a nightmare.
                          There is nothing wrong with a conventional cam. Or you can use a solid roller cam in a RWD block.
                            There's always teh 2.2 S10 bellhousing to allow for the starter on the wrong side.
                              Yea but the mounting will suck.
                              The starter is no problem
