2.8L (Gen 1) Specifications
  • 2.8L (Gen 1) Specifications
    General Data: All dimensions are in millimeters
    Type
    60 degree V6
    Displacement
    2.8L
    RPO
    LL2
    Bore
    89.0
    Stroke
    76.0
    Deck Height
    224
    Compression Ratio
    8.9:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    69 kPa @500 RPM; 205-380 kPa @ 2000 RPM
    (10 psi @ 500 RPM; 30-55 psi @ 2000R RPM)
    Cylinder Bore:
    Diameter
    88.992-89.070
    Out of Round
    0.02 (Maximum)
    Taper - Thrust Side
    0.02 (Maximum)
    Piston:
    Clearance
    0.017-0.043
    Piston Ring:
    COMPRESSION
    Groove Clearance
    Top
    0.030-0.070
    Second
    0.040-0.095
    Gap
    Top
    0.25-0.50
    Second
    0.25-0.50
    OIL
    Groove Clearance
    0.199 (Maximum)
    Gap
    0.27-1.25
    Piston Pin:
    Diameter
    22.9937-23.0015
    Clearance
    0.0065-0.0091
    Fit in Rod
    0.0187-0.0515 (Press)
    Crankshaft:
    Main
    Journal
    Diameter - 3 Dots
    67.241-67.249
    Diameter - 2 Dots
    67.249-67.257
    Diameter - 1 Dot
    67.257-67.265
    Taper
    0.005 (Maximum)
    Out Of Round
    0.005 (Maximum)
    Main Bearing Clearance
    0.032-0.069
    Crankshaft End Play
    0.06-0.21
    Crankpin
    Diameter - 2 Dots
    50.758-50.771
    Diameter - 1 Dot
    50.771-50.784
    Taper
    0.005 (Maximum)
    Out of Round
    0.005 (Maximum)
    Rod Bearing Clearance
    0.028-0.083
    Rod Side Clearance
    0.36-0.60
    Camshaft:
    Lift
    Intake
    6.65
    Exhaust
    6.94
    Journal Diameter
    47.44-47.49
    Journal Clearance
    0.026-0.101
    Valve System:
    Lifter
    Hydraulic
    Rocker Arm Ratio
    1.50:1
    Valve Lash
    Intake
    1-1/2 Turns Down from Zero Lash
    Exhaust
    Face Angle (Intake & Exhaust)
    45 degrease
    Seat Angle (Intake & Exhaust)
    46 degrease
    Seat Runout (Intake & Exhaust)
    0.05
    Seat Width
    Intake
    1.25-1.50
    Exhaust
    1.60-1.90
    Stem Clearance
    0.026-0.068
    Valve Spring
    Free Length
    48.5
    Pressure
    N @ mm
    Closed
    391 @ 40
    Open
    867 @30
    Installed Height
    40
    Valve Spring
    Damper
    Free Length
    *47.2
    Approx # of Coils
    4
    Fastener Tightening Specifications
    Item
    Nm
    Ft Lbs
    Air Injection Tube
    34
    25
    Air Injection Tube Nut
    25
    18
    Camshaft Sprocket Bolts
    23
    17
    Connecting Rod Bolt Nuts
    53
    39
    Coolant Outlet Bolts
    21
    15
    Coolant Pump Bolts (M6 x 10)
    10
    7
    Coolant Pump Bolts (M8 x 125)
    24
    18
    Coolant Pump Nut
    10
    7
    Cylinder Head Bolts (In Sequence)
    95
    70
    *Manifold Side*
    6 2 3 7
    5 1 4 8
    * Outer Side *
    EGR Valve
    25
    18
    Exhaust Manifold Bolts
    34
    25
    Front Cover Bolts *
    *** -10mm Bolt (4)
    50
    37
    *** -8mm Bolt (6)
    30
    22
    Flywheel Bolts
    70
    52
    Intake Manifold Bolts (In Sequence)
    21
    15
    H D A E I
    < Front
    G C B F J
    Main Bearing Cap Bolts
    95
    70
    Oil Filter Adapter
    85
    63
    Oil Pump Bolt
    41
    30
    Oil Pan Bolts (Rear Two)
    25
    18
    Oil Pan Bolts, Studs and Nuts
    10
    7
    Oil Pan Drain Plug
    25
    18
    Oil Pump Cover Screws
    9
    7
    Rocker Arm Cover Bolts
    8
    6
    Rocker Arm Studs
    65
    48
    Spark Plugs
    30
    22
    Timing Chain Damper
    21
    15
    Tortional Damper Bolt
    95
    70
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
