3.1L (Gen 2) Specifications
  • 3.1L (Gen 2) Specifications
    General Data: All dimensions are in millimeters
    Type
    60 degree V6
    Displacement
    3.1L
    RPO
    LH0
    Bore
    89.0
    Stroke
    84.0
    Deck Height
    224
    Compression Ratio
    8.8:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    69 kPa @500 RPM; 205-380 kPa @ 2000 RPM
    (10 psi @ 500 RPM; 30-55 psi @ 2000R RPM)
    Cylinder Bore:
    Diameter
    89.017-89.035
    Out of Round
    0.013 (Maximum)
    Taper - Thrust Side
    0.02 (Maximum)
    Piston:
    Clearance
    0.022-0.058
    Piston Ring:
    COMPRESSION
    Groove Clearance
    Top
    0.051-0.089
    Second
    0.051-0.089
    Gap
    Top
    0.18-0.41
    Second
    0.51-0.71
    OIL
    Groove Clearance
    0.2(Maximum)
    Gap
    0.25-0.76
    Piston Pin:
    Diameter
    22.992-22.997
    Clearance
    0.010-0.020
    Fit in Rod
    0.018-0.046
    Crankshaft:
    Main
    Journal
    Diameter
    67.241-67.265
    Taper
    0.005 (Maximum)
    Out Of Round
    0.005 (Maximum)
    Main Bearing Clearance
    0.032-0.077
    Crankshaft End Play
    0.06-0.21
    Crankpin
    Diameter
    50.758-50.784
    Taper
    0.005 (Maximum)
    Out of Round
    0.005 (Maximum)
    Rod Bearing Clearance
    0.028-0.086
    Rod Side Clearance
    0.18-0.44
    Camshaft:
    Lift
    Intake
    6.68
    Exhaust
    6.93
    Journal Diameter
    Journals 1 & 4
    51.03-51.08
    Journals 2 & 3
    50.77-50.83
    Journal Clearance
    0.03-0.10
    Valve System:
    Lifter
    Hydraulic
    Rocker Arm Ratio
    1.50:1
    Valve Lash
    Intake
    1-1/2 Turns Down from Zero Lash
    Exhaust
    Face Angle (Intake & Exhaust)
    45 degrees
    Margin *
    Exhaust
    2.70
    Intake
    2.10
    Runout
    0.3
    Stem Clearance
    0.2-.0.53
    Valve Spring
    Free Length
    48.5
    Pressure
    N @ mm
    Closed
    391 @ 40
    Open
    867 @30
    Installed Height
    43
    Valve Spring
    Damper
    Free Length
    48.5
    Approx # of Coils
    4
    Fastener Tightening Specifications
    Item
    Nm
    Ft Lbs
    Camshaft Sprocket Bolt 24 18
    Connecting Rod Cap Nut 50 37
    Crankshaft Damper Bolt 103 76
    Cylinder Head Bolt (In Sequence) (apply thread sealant to bolts)
    First Pass 45 33
    Final Pass Add 90 degrees
    *Manifold Side*
    6 2 3 7
    5 1 4 8
    * Outer Side *
    Exhaust Manifold Bolt 28 21
    Flexplate/Flywheel Bolt 83 61
    Front Timing Cover Case Bolt
    Long 45 35
    Short 21 15
    Intake Manifold (In Sequence)
    First Pass 20 15
    Final Pass 33 24
    Main Bearing Cap Bolt
    First Pass 50 37
    Final Pass Add 77 Degrees
    Oil Filter Adapter 39 29
    Oil Pan Rear Bolts 25 18
    Oil Pan Bolt and Nut (Except Rear 2) 6 7
    Oil Pump Bolt 41 30
    Rocker Arm Nut 27 20
    Rocker Arm Stud 25 18
    Belt Tensioner 54 40
    Throttle Body Bolts 24 18
    Timing Chain Damper Bolt 21 15
    Water Pump Pulley Bolt 20 15
    Water Pump To Block Bolt 24 18
    Water Pump To Front Cover Bolt 8 10
    Exhaust Crossover Pipe Nut 8 10
    Exhaust Heat Shield Nut 8 10
    Valve Cover Bolt 8 10
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • Gen 2 Flowsheets
      by SappySE107
      Might be a work in progress? Lets just get started and see where it goes. 28", 3.700" bore. PAP % 100cfm +5% 200cfm +1% 300cfm +1%
      Starting off with the bare head, using clay to bellmouth the port inlet.
      Next we will put the intake manifolds on, with the throttle body and all vac ported blocked and untested ports taped off. This shows flow distribution between all runners.
      This is the comparison sheet for the middle port using...
      08-18-2024, 11:04 AM
    • Using an adjustable pushrod for lifter preload
      by SappySE107
      Our engines use non adjustable rocker arms, so pushrod length is import to lifter preload, which is important for performance. Incorrect preload does change power on the dyno, or in extreme cases, the ability to run well or at all.
      There are 2 options for the adjustable pushrods, a shorter option custom made for wot-tech for use on 3100/3400/3500 LX9 engines. These measure below 5.700", which is very short for an automotive engine. The other option is a Comp pushrod that measures...
      07-17-2024, 11:29 PM
    • Gen 2 to Gen 3 Top-End Swap
      by bszopi
      The 3100 and 3400 engines are called Gen 3, because they are the third generation pushrod 60V6 engines. The reason for the swap is simple. Flow and design, both of which the Gen 3 triumphs all previous generations. The iron heads don't have splayed valves, D shaped exhaust ports, or in some cases even the larger valves (1.42/1.72). The Gen 2 Aluminum head engines are the most popular to do this swap, but no matter what you start with, the same steps apply. The Gen 3 parts have D shaped exhaust po...
      11-16-2010, 10:53 PM
      by bszopi
      06-15-2010, 04:25 PM
    • 2.8L (Gen 2) Specifications
      by bszopi
      04-21-2010, 07:18 PM
