4T65E
  • Appendix
  • 4T65E and 4T65E HD (99+) N-Body Swap
    ** Note: It is best to use a transmission from a 97-02 as changes made in 03+ models may require additional work.
    Information sourced from: http://www.tripleedgeperformance.com...bout_using.php
    There are a number of changes in the 2003/2004 and newer 4T65E transmissions, and below is a simple list of the main differences.
    1. Beginning around June of 2002, which will apply to 2003 model years, the valve body and oil pump assembly were changed. Changes are rarely made because it is better or needed, but rather than to simplify assemble and lower costs. Some of the new style pumps were fitted to the old style valve body, while some of the old style pumps were fitted to the new style valve body. The older style being a 2 piece pump and the new style being a 3 piece pump. These will NOT interchange without a matching valve body!
    2. The Valve Body changes are minor, though must be used with the appropriate oil pump and Fluid Pressure Switch Assembly. Most all 2003 model year vehicles received a newer style valve body which incorporates a much smaller fluid pressure switch as it only detects TCC operation being ON or OFF. The older style fluid pressure switch assembly had a total of six pressure switches which would detect fluid pressure present during each gear currently applied and signaled the PCM this information. This change alone is a main reason the 2003/2004 and up transmissions WON’T just readily work with an older car as the PCM is different and no longer uses the fluid pressure switch on the newer models.
    3. The Pressure Control Solenoid, PCS is different and will NOT interchange, though it may physically fit in either valve body. The solenoid is designed different and does not function the same as the earlier units. If used it can destroy a good trans because pressures will not be correct as the valve body is calibrated different to be used with the new style solenoid as well as different PCM calibrations were made.
    4. The Internal Wire Harness was also changed to work with the above changes, as well as most all models used an Internal Mode Switch, as the earlier models had one that bolted on the outside of the trans case located directly under the manual shift lever. Some 2000 and up models already incorporated this and it CAN be used in vehicles that came without it with minor modifications to the wiring harness OR by just bolting on an older style switch as it was on the original transmission.
    5. 2004 and UP TapShift style transmissions use a UNIQUE valve body and channel plate and WONT work without the proper PCM! The manual valve linkage and manual valve inside the channel plate is different, as well as the separator plate and valve body to accommodate these changes. It simply put WONT work and should not be tried.
    6. ALL channel plates from January 2004 and up included an internal converter drain-back ball and spring. Because of this, this channel plate is not interchangeable with earlier models. From what I have found most 97-99 transmissions also used this with an earlier style Thread-In cooler line fitting. From 2000 and up they replaced this type of fitting with a quick connect fitting and these had a drain-back ball and spring in the return cooler line fitting, while the 97-99 transmissions did not. While it is certainly possibly to use the 2004+, or 2006 transmission for that matter the channel plate and valve body must be replaced BUT you must check to make sure the original channel plate also had the drain-back ball and spring. The return cooler fitting in the case was changed and was made a different thread size on purpose so you cannot use an earlier style fitting in the case as this would create a very bad restriction in cooler line flow.
    Disclaimer: All information provided in this article is for reference purposes and is believe to be correct by the author at the time the article was completed.
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • 4 Speed Automatic Transaxle Info
      by robertisaar
      The following pages contain information on specific transmission models from the 4T60, 4T60E and 4T65 family(4T40/4T45 and 4T80 information may be in the works, stay tuned). For now, it is NOT an all-inclusive list, but any missing information would be appreciated. Miscellania: 4T60E Differentials with an asterisk are "fine pitch" final drives. Sun gears, internal ring gears, and pinion gears are NOT interchangeable with other final drives. 4T65E with "IMS" have the newer type of s...
      10-08-2010, 01:48 PM
      by onefastV6
      So you have significantly modded your engine and now your transmission seems to be the weak link of your build. You have a few options to upgrade the stock 4T45E transmission which can be rather costly, or you can swap to the stronger 4T65E series transmission which seems to be uncharted territory for many. The purpose of this article is to provide a little more insight on what it will take to swap a 4T65E transmission into your 99+ N-body. ...
      09-20-2010, 08:36 PM
    • 4T4x-E Mechanical Specifications Information
      by bszopi
      4T40-E/4T45-E Automatic Transaxle Unit Repair
      NOTE: Click on images to see a full-size view.
      Fastener Tightening Specifications
      End Play Specifications
      Reverse Clutch Backing Plate Specifications
      On-Vehicle
      General Specifications
      Range Reference
      Shift Solenoid Va...
      08-18-2010, 08:25 PM
    • 4T65E Hardened 4th hub and solenoid upgrade
      by Tbay99Venture
      INTRO This is a guide on how to service your transverse automatic transmission without a lift. All work is done with the vehicle on jack stands. Once the cover is removed the valve body is left attached to the channel plate. This assembly can then be moved to a workbench for easier servicing if valve body work is in your plans. In any case the transmission drive chain, pump, 4th gear assembly and many other parts can be repaired or upgraded at this time. In the description below the term "c...
      07-24-2010, 09:59 PM
