Need More hp out of my 3100
  • rebelracer29
    • Apr 2010
    • 20
    I race at a small banked oval track i got a 3100 beretta. I need more hp to keep up with everone elsa. Does
    anyone know of mods i could do to make my 3100 faster. Cam heads anything. I get the engine uder alot of strees high RPMS. I no that a 3400 tb would help but what else
    let's see... anything, actually...
    swapping in a 3500 would be a good start though.
    • rebelracer29
      • Apr 2010
      • 20
      I cant do that cant have a engine bigger then a 3.1
        if we can stick 3500 UIMs on a 3100, then the reverse is probably true as well... no one would know unless they actually measured bore and stroke or knew the character stamped on the side of the block meant 3500.
        • rebelracer29
          • Apr 2010
          • 20
          well next season i might do that i dont have the money to buy a new engine now but u no next years might be different. do u no if a cam would do anything or anyhting that wont cost as much. i am putting a 3400 tb on but thats not much more hp
            • 13499
            wot-tech.com. Large port manifolds would be a great upgrade with the 56mm TB. There are billet throttle bodies and ported heads and cams and forged pistons. You can do just about anything as long as you can tune it.
            • rebelracer29
              • Apr 2010
              • 20
              thanks so a bigger cam wont mess anything up
                you start talking cams/headwork and you're going to need to be able to tune for it...
                • rebelracer29
                  • Apr 2010
                  • 20
                  what do u mean tune for it
                    Change computer settings to be optimized for your engines characteristics. Kind of like dialing in a carb and distributor, only doing it in the computer.
                    • rebelracer29
                      • Apr 2010
                      • 20
                      ok well how do you do that change the settings. so if u dont tune it for bigger heads and cam they will mess up the engine. Is that what u guys are telling me +
                      • 86FieroSEv6
                        • Feb 2010
                        • 527
                        I had put a mild performance cam and roller tip rockers in '91 'retta GT with good results. It really picked up on bottom end and mid range and the factory settings handled it just fine. That's probably about as far as you can go without re-tuning the ECM.
                        • rebelracer29
                          • Apr 2010
                          • 20
                          ii have a 96 with a gen3 3100 is differnt the the old gen2 3.1 i no ucan put cams and things in the gen 2 but dont no bout the gen3
                            there are some good gen3 cams rolling around... ben can help with that.
                            • rebelracer29
                              • Apr 2010
                              • 20
                              who is ben thats what i need a good gen3 cam that wont mess my engine up i know there was way to make them faster.
