3500 Ported Manifold Set
    • 13531
    http://60degreev6.com/store/index.ph...d&productId=60
    $400 including the manifolds. I think the flow sheet will get some attention. This is why the 3500 top end is bad ass, not just because the head design is better but the manifold design is better too, especially ported. I have never had the manifolds outflow my clay entrance, but the dimple in the lower intake, modified to my spec, really helped with the direction of air
    $175 for porting alone. Its not the same as the 3500 plenum that is on the store, as that was done for the 3400 gasket,not the 3500. I am about to edit it so it reflects this difference.
    • 9191
    Very nice... I was confused about the numbers at first, but upon reading the description at the bottom, it all came together. Nice to see that you are loosing ~4% flow through the ported manifolds compared to 10% for the stock manifolds. And the fact that the heads increase flow at the low lifts is just awesome.
    • farmerz24
      • Feb 2004
      • 361
      sweet... cant wait to see the #'s with the ported heads!
      • zhd1000
        • Jul 2005
        • 8
        if i wanted to get just a ported lim to work with the 3500 heads and keep my 3400 uim.. how much would a ported 3500 lim be? or am i not seeing it in the store..
        2000 Grand Am GT
          • 13531
          I need to put them up individually as well as make the ported 3500 heads stand out more instead of being listed as new 3500 heads.
          Would you be sending a manifold in or not? Pricing should be similar to the 3400 lower. I will work on the store later tonight if I get a chance.
          • zhd1000
            • Jul 2005
            • 8
            was planning to send in parts to be ported..
            2000 Grand Am GT
              • 13531
              I have the 3500 lower ported for 3400 upper on the store now with the option to send parts in. Let me know if you need anything else setup on the store.
