EGR Adapters
  • dnalbach
    • Oct 2006
    • 69
    EGR Adapters
    Do the EGR adapters in the Store for the digital EGRs have to be on vertical mounts, or will they work with a side mount as well?
    • 13534
    They are not designed for the side mount used on the 2000 and newer manifolds.
    • dnalbach
      • Oct 2006
      • 69
      Ok thanks.
      I am having trouble finding a 3400 vertical in my area. I'll keep looking. Any particular year/model that was known for that?
        • 13534
        96-99 minivans will have the EGR mount that works with the adapters.
          I'm working on getting my machinist to provide you with a horizontal mount EGR along with the other verticals I sell you... I now have a 2005 motor sitting around so he will have an intake to work with.
          • geldartb
            The Situation
            • May 2004
            • 1994
            the adapter for the 96-99 is awesome. did the job great fits nice and is machined very wel. well worth the money.
            99 Grand Am GT
            1357 cam 227 233 .050 dur
            515 515 lift 112 lsa
              I will forward that info off to my guy, I'm sure he'll appreciate it.
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                TTT got the 00+ adapters ready?
                There is a newbie on clubgp who might need 1
                02 GTP - 90* > Failboat
                www.blackbombshell95.com
                • ihatemygrandamg
                  • Jun 2006
                  • 108
                  Couldnt you just get the right egr valve you need? Would the sensor still work with a different year valve?
                    • 13534
                    That is correct. The only adapter you need would be 00+ to 95 and older. The 96-99 connector is the same as 00+ so you just need the right EGR and tube to the exhaust manifold.
                    • dnalbach
                      • Oct 2006
                      • 69
                      Why the 96 pipe?
                      In the instructions in the store and that came with the adapter, it specifically lists a '96 EGR pipe from the exhaust manifold to the intake. Why is the '96 needed instead of the old '95 I already have? I am having difficulty procuring a '96 pipe as we just had a snow storm here in Denver recently and cruising the yards is absolutely miserable. Can I use the '95 pipe even temporarily?
