3500 ffp crank trigger
  • rickykline
    • Oct 2006
    • 345
    ready yet? cash in hand if it is
  • rickykline
    • Oct 2006
    • 345
    not yet?
      • 13531
      I thought they were close but I dunno how long before I get them.
        i've got the new style and it looks great.. have yet to run it though.
        • CNCguy
          Bisong eater :P
          • 1017
          I didn't realize that someone was waiting for one. The new wheels are finished but we are redesigning the CPS mounts for additional clearance on other vehicles. I will look to see if there are enough components to throw a set together using the original CPS mount. If so, I can send it out today.
          MinusOne - 3100 - 4T60E
          '79 MGB - LZ9 - T5
          http://www.tcemotorsports.com
          • rickykline
            • Oct 2006
            • 345
            im running the 3500 in a beretta so the mount style doesnt matter for me.. LMK...
              Actually it does, well you can modify it like the other person did that put a 3500 in their beretta. You just grind/sand off the bottom mount to match the thickens of the mount bracket that goes under it.
              Ricky, are you going to swap timing cover and crank pulley so you can use the 24x sensor, or some how editing the need for it out of the ECM?
                Hack saw works too...
                • rickykline
                  • Oct 2006
                  • 345
                  i thought the j body was the only chassis that didnt clear the trigger?
                    L body clears it, but where the trigger bolts to, one of those bolt holes has a motor mount bracket bolted on (the one that goes to the lower dogbone). So you need to shave off the thickness of this bracket from the trigger, put the bracket on, then the trigger, then the bolt.
                    • rickykline
                      • Oct 2006
                      • 345
                      well i need on of these triggers..
                        there is one in stock at the store...
                        And its a simple fix that Isaac is saying, you should be able to figure it all out when you see it.
                          • 13531
                          I have 2 of the new style triggers that work with the FFP pulley now.
                          • rickykline
                            • Oct 2006
                            • 345
                            how much?
                              • 13531
                              same price for these 2. Just order one off the store and I will know what you want. I have 1 old style to sell as well before I update the store pics.
