I need videos
    • 13520
    I need videos
    I am updating my store and have already started linking to videos showing off what the cams sound like at idle, and how they perform on the track. If you don't want me linking to your video, please let me know.
    I hope to have a customers section to showcase what you have done and have all the information in one place for others to see. Anything you can give me for information and multimedia for the site is appreciated.
    That is what I have so far.
  • geldartb
    The Situation
    • May 2004
    • 1994
    did the specs for my cam change. the ones in the new page you made are different from what was listed before.
    the old specs are listed in the video the only ones i had listed that are different is the @.050 that i remember.
    i like the new setup for the page though
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
      • 13520
      Yes, those are the actual grind specs. The sheet that I have for their grinds are all based on a cam master lobe that is larger. This means we lose a little duration and possibly lift compared to the advertised grind spec. 230/236 is 227/233. The 206/260 grinds are 205.4/262.4.
      Now that I have actual grind specs for quite a few cams, I have switched everything to actual spec. The custom cam page will be very fun to explain all of this... I would like to keep it to certain cams that are popular and delete the redundant grinds, 1161 and 1429 coming to mind right now for the NA grind.
      • mfuller
        Mr. Common Sense
        • Nov 2003
        • 374
        I'll get you a mildly-built 1280 video when Mark finishes my build.
        Matt
          • 13520
          Get me some assembly and install vids The more pictures and videos the better.
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            hey hey im on there!
            i'll have to get you another track video this summer once its tuned all the way
            • PCGUY112887
              • Feb 2006
              • 1067
              Glad to see my video
              Also glad to know that someone elses valve train sounds like mine with the cam! That noise always kinda bothered me, even after Superdave and others told me it was normal I still wondered... now I can see that the Stage 4 in that Grand Am sounds just like mine (although mine isn't quite that loud).
              SpudFiles
              Theopia
              Enjoy life online.
              • geldartb
                The Situation
                • May 2004
                • 1994
                even since that video its gotten a wee bit quieter. ill snag a vid once i get the headers back on.
                but compared to what i first started with its a pretty damn good improvement. i still think i only have about 200 miles on it so far and then winter/cold came up so it kinda got shelved until spring when i can start tuning.
                my next video will most likely be with the 3500 top end just need to pick up a LIM and all the gaskets.
                99 Grand Am GT
                • mfuller
                  Mr. Common Sense
                  • Nov 2003
                  • 374
                  I don't know if you need a stock cam for comparison, but I wanted to get a good clip of my current exhaust before the new motor goes in with the 1280 cam and street/strip heads....
                  Matt
                  • geldartb
                    The Situation
                    • May 2004
                    • 1994
                    for comparison sake this is of the same exhaust from the downpipe to the muffler but on the stock cam.
                    99 Grand Am GT
                    • BoostED00GagT
                      BooStIN!
                      • 38
                      got a idle vid of my stage 3 turbo cam i got from WOT store..its all yours and thanks again..
                      00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
                      99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
                      • 19Cutlass94
                        • Apr 2005
                        • 770
                        i duno if anyone else has the 1211 cam, but i can get a idle vid up soon, and a track mvid next month. although i have a nice idle problem from a vaccum leak....
                        3400/Getrag 284 5spd
                        350/NV3500 5spd
                        2014 Chevrolet Malibu LS
                          • 13520
                          I don't think a video of the cam idling with a vacuum leak is going to do anyone much good. I don't recommend having vacuum leaks and that might confuse someone:P
                          • 19Cutlass94
                            • Apr 2005
                            • 770
                            well i tell you this vacuum leak was very loud and a nice whistle. but i found it, which was something stupid, and well see if its fixed before i get a video up of it.
                            350/NV3500 5spd
                            • 19Cutlass94
                              • Apr 2005
                              • 770
                              I found the vacuum probem, now i can get some videos up for ya.
                              350/NV3500 5spd
