Underdrive pulley with damper for 3400
    • 13531
    Powerbond is going to be making the SFI Race underdrive pulley with 24x reluctor built in. Price range estimated $200. If you are interested, please post up. This is the same company that makes are stock units, so durability and quality are not an issue
    • 9191
    Interesting. Would definitely be on my list of things, once I get back to working on these engines...
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      Sounds like something worthy of my fantastic 3400 engine. I'm intersted.
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
        I might be in for one as well, pending actual specs.
          • 13531
          They make 10% and 25% UD pulleys but I don't know if both would be available. If you have a preference go ahead and post away.
            • 9191
            A little info on Powerbond... http://www.precisionparts.com.au/Pag.../powerbond.htm
            • sanjay
              • May 2004
              • 142
              I'm definately interested. Would these be in steel or aluminum?? (Not sure if an aluminum balanced UDP can be made)..
              • sprucegagt
                Old School KI
                • May 2005
                • 703
                You know I'm interested.
                Your local OBDII moderator
                2000 Grand Am GT w/ WOT parts
                • 98blackbu
                  • Sep 2008
                  • 3
                  Id be down.
                  COP: you were going 96 in a 55mph zone. your plates on upside down, u failed to signal, do you know why i pulled you over?
                  ME: because of the for sale sign, u wanted to see this fine piece of automotive history up close and personal?
                  COP: clever.. clever.. very funny. now take off while im laughing before i ticket you. get outta here.
                    Would love to see this happen.
                    • mfuller
                      Mr. Common Sense
                      • Nov 2003
                      • 374
                      GODDAMNIT! I just used a factory pulley to have my bottom end balanced!
                      Matt
                        I thought our cranks were internally balanced already so when you balance a lower end all your doing is matching all the rod/piston assy's to the same weight and such and then you would just use a balanced pulley... in other words I did not think we had externally balanced motors.
                          We don't have externally balanced motors. Nothing to worry about.
                            Thats what I thought, so having your lower end balanced with the stock dampener is either the wrong way, or it's not even being used in the balancing process.
                            • mfuller
                              Mr. Common Sense
                              • Nov 2003
                              • 374
                              So I could conceivably put one of these SFI Race serpentine balancers on my balanced 3400 bottom end and not have any issues.....right?
                              If so, very interested.
                              Matt
