Cam specs 1615 & Stage 2 NA
  • sanjay
    • May 2004
    • 142
    Ben can you post the specs of the 1615 grind and the Stage 2 NA cams??
    • 13531
    206/206 260/260 .533/.533 lift 113 ICL 112 LSA is "stage 2" territory. I also have 2 other grinds with similar power output, 1 of which will work with yellow LS6 springs.
    I don't know the 1615 specs, as they don't exist on WOT-Tech anymore. I use Comp Cams now, not regrinds.
    • sanjay
      • May 2004
      • 142
      You don't have access to the list you used to have with all the specs in the store in the store??
      I need to sell my 1615 and I have to post up the specs.
        • 13531
        I have 1 print out before I deleted everything and it wasn't in front of me out in the garage.
        280.6/283.8 duration seat to seat 225/227.6 duration .050" .603/.562" lift 111 ICL 111 LSA
        I didn't assume you were selling 1 cam when you asked for the stage 2 cams along with it.
          I have the entire list saved somewhere...
          Ben, is the cam you sold Damon a regrind or a new Comp one?
            • 13531
            comp
            • sanjay
              • May 2004
              • 142
              Dave, if you can find the list can you email it to me??
                You crazy bastard you... LOL why on earth would you delete everything.
                  • 9191
                  I'm pretty sure he has it in at least 1 backup, since he made a complete backup of the store prior to our server move.
                    • 13531
                    Yeah, i have a backup somewhere probably but I got rid of everything on the server because I don't want to add confusion by any old links people may have to my old store pages. I should have a paper copy somewhere.
                    • bungee91
                      • 18
                      Sorry for the late reply, however does this help at all?
                      • sanjay
                        • May 2004
                        • 142
                        Yes it does. Now if anyone can post the Grind numbers for the old stages I have all the info I need. I'm assuming Stage 2 is the 1393 grind??
                          Yes I believe so.
