Diamond Piston bore availability
  • ALLTRBO
    • Dec 2008
    • 101
    Would it be possible to get Diamond Pistons for the 3400 made .100" over? If so, how much extra $$$?
    '88 Fiero GT - Project MIDTRBO
    '10 Camaro LT/RS
    The rest of my cars are for sale (Click here)
    There's no replacement for turbo placement
    We used to have a chart that showed safe specs for engine bores, and I believe that .060 was the most you want to go and still be in the safe bore wall thickness range in the 60v6 family.
    • 2.8-350TBI
      RWD FTW!!!
      • Sep 2009
      • 350
      Under .060 or bust
      Literally.
      Unless you send your block off for hardening, but thats a different story.
      Originally posted by Mars
      Haha ^ Wrong Wheel Drive.
      No 60šV6 at the moment
        Originally posted by 2.8-350TBI View Post
        Under .060 or bust
        That made me lol.
        • ALLTRBO
          • Dec 2008
          • 101
          The engine would only be about .020 over, I just want .100 over 3400 pistons.
          <<< Not a newb engine builder.
          '10 Camaro LT/RS
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            Last I knew, 35.. I mean .100 over 3400 Diamond pistons were not available.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
            • 2.8-350TBI
              RWD FTW!!!
              • Sep 2009
              • 350
              3500 block???
              • ALLTRBO
                • Dec 2008
                • 101
                Yep, 3500 block, but 3100/3400 compression height so not 3500 pistons, just 3400 pistons .100 over.
                I know it's a longshot, but if I don't ask then I'll never know.
                '10 Camaro LT/RS
                  That's what I was thinking. Might not even be a GM engine for all we know.
                  EDIT: Ninja'd FTL!
                  This going in your lawn mower in your sig? J/k That pic has always cracked me up, lol.
                  • ALLTRBO
                    • Dec 2008
                    • 101
                    I do ride a Kawasaki Ninja, afterall.
                    Yes it's for the mower, I decided that the 8hp engine just wasn't cutting it.
                    '10 Camaro LT/RS
                      • 13534
                      I know its possible and I don't think that bore size will increase costs but I will find out for sure.
                      • blackbombshell95
                        Kaiō-ken X 10
                        • Jun 2004
                        • 1386
                        Before you bore out your cylinders you want to pay for a sonic check to see how far safely you can bore out the cylinders. Every block is different, some 3400's might take .030 more and some might take .050 more. But I see you have a 3500 block and I have no idea how thick the cylinders walls are.
                        I had my 3400 block sonic checked and I safely able to bore it .030 over. Some areas were super thick and other areas weren't.
                        U can see on Cylinder #1 I have a real thin spot and If I bored it .100 over it would be dangerously thin. Good luck with whatever you decide to do.
                        02 GTP - 90* > Failboat
                        www.blackbombshell95.com
                        • ALLTRBO
                          • Dec 2008
                          • 101
                          Great, thanks!
                          Blackbombshell95, that's a good idea, though I'm pretty sure .020" over (.02126" actually) won't be a problem on a 3500 block. The bore is already 2mm larger than a 3400 (94mm vs. 92mm)
                          Thanks for the information on your block, cool to know!
                          '10 Camaro LT/RS
                            • 13534
                            They are available and there is no price difference for that bore size.
                            • ALLTRBO
                              • Dec 2008
                              • 101
                              That completely kicks arse, thanks for finding out. I should be ordering some within the year, a lot sooner if the current used shortblock ends up with problems once it's fired.
                              Anyone want to buy a twin-turbo 350 6-speed '90 IROC-Z? It only needs a 'little' (read: a lot) of work! When I'm done with my 60V6 Fiero, my TT V8 won't know what hit it.
                              '10 Camaro LT/RS
