Street/Strip Cam Idle
  • ShieldsM
    • Jun 2010
    • 21
    A couple of video's, hope you like them
    Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
  • geldartb
    The Situation
    • May 2004
    • 1994
    not bad it's got a nice steady idle.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      Sounds good......very similar to mine (yours is just a bit louder).
      Had it tuned yet? I saw some pretty decent gains after tuning with similar mods.
      Matt
        • 13534
        Very nice Idle quality videos can really help people figure out which cam they want. That engine bay looks great too!
          I heard the same cam running on OBD1 in a 3400 with headers and it sounded quite a bit different... maybe the SFI is helping it out...
          Sounds good though, very smooth.
          • ShieldsM
            • Jun 2010
            • 21
            Thanks for the comments
            • bob442
              Show Me Your KITS!
              • Nov 2008
              • 1305
              what chain did you have prior? i would like to know if the 99 gm chain holds up with this cam...
              • ShieldsM
                • Jun 2010
                • 21
                I was using the OEM, witch was very small. This chain streched in 5K, but this is do to the valve springs. I hear the pre 99 work great, but now I'm running the TCE timing kit with crank.
                  I have my 99 GM setup on there still and its holding up good. As noted though, its typically the springs that your using that will also speed up chain wear. I also had my chain cryogenically treated so that may be helping a bit. TCE is a nice solution, but I'm not up for tearing the whole motor apart again to have the crank turned.
                  • robert 1980
                    • Aug 2009
                    • 302
                    Wow hearing jon's car and now your grand am. I want a cam really bad.I would really like to do a engine build in the very near future.
                      HAHA, one thing at a time now Rob... Lets get the stock pig running right, and then we can get you a mild street and strip cam to have some fun with.
                      • geldartb
                        The Situation
                        • May 2004
                        • 1994
                        here's mine for video sake. IIRC when Ben had the user videos on the WOT site he called it a stage 4 n/a
                        i've had the 99 GM timing set in there from the start and haven't taken it off or heard a peep from it yet. while mine may not have as many miles on it as Jon's it get's driven just as hard.
                        99 Grand Am GT
                        • robert 1980
                          • Aug 2009
                          • 302
                          I agree 100% with you there i can't wait.I really can't wait to see what it can do!!!!
                          • bob442
                            Show Me Your KITS!
                            • Nov 2008
                            • 1305
                            i could really use another video for a street/strip cam. or any other videos infact
                            • mfuller
                              Mr. Common Sense
                              • Nov 2003
                              • 374
                              Whatever exhaust you run has a lot to do with the tone of the cam.....you can barely detect mine.
                              Matt
