For Sale: Grand Am Coil Over Kit
    • 13522
    $750 + shipping. This is the test set with about 500 miles on it, using new KYB struts. Would be great for a track car, as handling is improved substantially. Will not lower the car however, unless you buy shorter springs.
ID:	380914 Click image for larger version
  • eckoxl
    • Jul 2009
    • 230
    PM'd
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      What spring rates did you use? 2.5" ID springs, I'd assume.
      Eibach linear springs or someone else?
      I remember when I had my coilovers (double-adjustable Koni yellow dampers with Eibach race springs), I ran 300# springs in front and 200# in back, and I thought it was stiff on the street.
      Of course you know what a slow driver I am.....
      Matt
        • 13522
        Sold!
        We do not know what the spring rates are, but plan to do testing with different springs as long as the market is there for such a thing. Yes, 2.5" ID springs. Are those koni struts still available?
        • mfuller
          Mr. Common Sense
          • Nov 2003
          • 374
          I had OEM strut housings retro-fitted with Koni "wet kits"; the conversion was done by Truechoice Motorsports in OH.
          I'm sure you can still gets the kits they used as there are several different 8611 racing damper kits available.
          Here's what they looked like before I had them converted to coilovers:
          And after:
          Matt
            • 13522
            If anyone else wants the same setup for 750, let us know. Matt, those look awesome. Is that the setup you had when you came to Warsaw?
            • mfuller
              Mr. Common Sense
              • Nov 2003
              • 374
              Thanks.
              No, I had those years ago when I still tracked the car. Awesome handling, but a tad stiff for the street. Although I've been thinking about trying to buy them back from the guy I sold them to.
              When I came to Warsaw, I was on H&Rs/KYB AGXs.
              Matt
              • unchained01
                • Jan 2011
                • 388
                How was the ride ? You said handling was improved. And will these be available with AGX struts. Or something comparable ? I don't care about spring rates. I used to work at a race shop for dirt track cars. And can get different springs and have access to longacre scales. And can test the spring rates also on their equipment .
                  • 13522
                  Ordered the AGX struts and more parts to make another coil over set. We will have updates after we get it installed and tested. The first set, the front was great, the rear was a little bouncy over speed bumps. On a nice road, its awesome. Cornering was much much much better. We need to get the springs sorted out eventually and the more help we can get, the better.
                  • 95SleeperAcheiva
                    ArtofOlivia"PocketRocket"
                    • Jun 2006
                    • 694
                    what year GA are they for? Fit a '95 Achieva? I have a set of stock struts gutted and trimmed for the Koni insert but that's as far as I got. How much more to use Koni's instead of KYB? Can we pick a color of powder coat? :P
                    What is the meaning of life and the universe? I figured I threw in enough questions I'd throw that one in too
                      • 13522
                      99-05, no idea on koni, not powdercoating anything. We can make coil overs for anything but we need a vehicle. Price depends on the cost of parts and the labor involved to make it happen.
                      • kwhauck
                        Olds Sleeper
                        • Aug 2006
                        • 379
                        Originally posted by mfuller View Post
                        Thanks.
                        So since I got them from John, you mean me?
                        • mfuller
                          Mr. Common Sense
                          • Nov 2003
                          • 374
                          Perhaps.
                          Matt
                          • kflo 93 gt
                            Bangin' Gears
                            • Nov 2003
                            • 238
                            Can you build a front set of these for a Beretta?
                            I pay $$$$. Indeed, that is four dollar signs.
                            I have a fifth one waiting, if need be.
                            14.60 @ 96.33 for now...
                              • 13522
                              We have to look at the stock setup but I would be surprised if we couldn't make it work. Having a car would be a good step forward:P
