Internal Engine Coatings
    • 13531
    CBX POWERKOTE (Cermet Coating Thermal barrier)
    Designed for Performance engines running; Nitrous oxide, Supercharged or Turbocharged. For all other applications use CBC2. Creates a hard surface specifically designed for engines running High volumes of fuel and/or high compression ratios.
    • Thermal barrier coating.
    • Reduces part temperature. Keeps heat in combustion chamber longer through the power stroke.
    • Increase torque and H.P. Increase combustion chamber efficiency.
    • Reduce fuel consumption.
    • 9191
    That looks nice. Pricing on your store site?
      • 13531
      I labeled high compression, then changed it to 3.4 DOHC so I can just call them by what they are for. Once I have the camaro pistons skirt coated, I will have a listing for them as well.
