Cam Timing Verses Performance Question
  • Jogasz28
    • Dec 2006
    • 132
    This question regards a stock 3.4 Litre engine.
    I have seen threads with cam timing tools that bolt on at the location used for the cam hold-down. This has got me wondering if the stock cam timing of using the cam flats to get 180* opposite at TDC's is the optimum cam timing for my stock engine.
    I would like to know if a different cam timing would be beneficial as I will be getting to this step very soon.
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    • 13531
    6 advanced intake, 6 retarded exhaust. I like it a lot with an automatic car. Doesn't mess up the computer bad or anything either for 94-95. Thats crank degrees. Its 3/3 cam degrees.
    • Jogasz28
      • Dec 2006
      • 132
      I appreciate the reply.
      Could you expand so I can fully understand what you mean?
      How do I set the cam (i.e., tool needed?) at those cam or crank positions?
      jogasz28
      ______________
      '68 RS Camaro,
      '99 Monte Carlo LS
      • Jogasz28
        • Dec 2006
        • 132
        Something just occurred to me.
        Couldn't a "sticker" be developed that could be attached to the dampener, with an alignment mark in the middle of the sticker positioned at the dampener TDC notch that would accurately scale the degrees of crankshaft position (3/3) before and after TDC so you could use it to set the camshaft positions (6/6) while the cams were positioned at the camshaft "flats" ?
        jogasz28
        ______________
        '68 RS Camaro,
        '99 Monte Carlo LS
          • 13531
          I was originally going to try to do a sticker type setup. The timing tool was nice but no one makes them now. You got it backwards though. 6 crank degrees = 3 cam degrees. The cam spins at half speed. 6/6 is crank degrees.
          It would also be possible to make some hold down that set it to 3/3 at the cams.
          • Jogasz28
            • Dec 2006
            • 132
            Thanks for the correction. I'm a backwards kinda guy. <LOL>
            In order to make a hold down at 3/3, you'd have to machine the correct angle to register the flats at the correct angle from "flat", right?
            Sounds like a CNC type of job.
            jogasz28
            ______________
            '68 RS Camaro,
            '99 Monte Carlo LS
            • Jogasz28
              • Dec 2006
              • 132
              Could the 6* of crank travel be converted to a measurement from the timing mark on the dampener?
              Or,
              If anyone has a tool and has set their cam at 3*, couldn't they measure from where the engine cover pointer hits the dampener to the dampener factory TDC mark?
              jogasz28
              ______________
              '68 RS Camaro,
              '99 Monte Carlo LS
              • Grim[Z34]
                • Jan 2005
                • 82
                Idont know but if you figure out an easy way to do it let me know because im putting P&P heads and getting some new pistons, rings and replacing all that good stuff..
                So i might as well advance or decrease the timing while im putting it all together..
                ~Rich
                • grandprixgtp_91
                  • Nov 2003
                  • 758
                  i made a sticker on cad. and glued it to the crank dampner, and it worked awesome. it was prettty easy.
                  Jake
                  • Jogasz28
                    • Dec 2006
                    • 132
                    Jake
                    Will it work on a '95 3.4 Litre?
                    If so, could you share?
                    jogasz28
                    ______________
                    '68 RS Camaro,
                    '99 Monte Carlo LS
                    • grandprixgtp_91
                      • Nov 2003
                      • 758
                      i never saved it, i just made it printed it and used it, you can easily make one by taking a protractor on measuring out the degrees on a piece of paper cutting it out,and gluing it to the dampner.
                      Jake
                      • Jogasz28
                        • Dec 2006
                        • 132
                        Jake
                        Would you take the diameter of the dampener into account?
                        Would you measure the diameter of the dampener and make your own circle, drawing the 3* from say noon, then measure from noon to the 3* mark and use that length on your dampener from the TDC mark?
                        Would that be accurate enough?
                        jogasz28
                        ______________
                        '68 RS Camaro,
                        '99 Monte Carlo LS
                        • grandprixgtp_91
                          • Nov 2003
                          • 758
                          you need to measure from the centre of the crank dampner(middle bolt) to the edge of the crank dampner, and extend the lines as far as that. then it will be accurate
                          Jake
                          • joey b
                            • Feb 2004
                            • 75
                            actually you could bend the steel stock at the bolt hole and using a lil of trigonometry make a set. I would suggest making 2 and welding one to the other after bending both to reinforce it.
                            92 cutty auto with a 97 3.4
                            93 convert with 3.4
                            • Jogasz28
                              • Dec 2006
                              • 132
                              O.K., I'm blonde:
                              Which bolt hole?
                              How would it attach?
                              Bend it from where to where?
                              jogasz28
                              ______________
                              '68 RS Camaro,
                              '99 Monte Carlo LS
