Rough HP Estimate?
  • grandprixgtp_91
    • Nov 2003
    • 758
    Rough HP Estimate?
    Hey guys im up at school for GM product service training and i might get to throw my car on the dyno tommorow , so what do you guys think i will run at the wheels? just to roughly guess what i should have.?
    my setup is :
    1991 Pontiac Grand Prix GTP
    3.4L DOHC
    Getrag 284 5 Speed Manual
    Ported heads
    Ported Upper and Lower Intake
    Ported and tappered throttle body
    6*x 6* cam timing
    ffp under drive pulley
    ffp dogbone
    k&n cone filter
    flowmaster 40's series mufflers
    high flow cat
    and Bens wonderful chip!
    i hope i can print the results and then ill scan them and post them, just wondering what u guys think i will drop at the wheels.
    Jake
  • HayesPerformance
    • 783
    1200hp!!!!!!!
    LOL Just kidding!
    hahahahaha
    Maybe around 240hp at the crank as a guess.
    1991 Grand Prix STE
    3.4 DOHC
    1 of 792 Produced
    Extensive Mods Done
    1991 Lumina Z34
    3.4 DOHC
    Getrag 284 5spd
    1 of 30
    • HayesPerformance
      • 783
      Maybe even 250hp
      1991 Grand Prix STE
      3.4 DOHC
      1 of 792 Produced
      Extensive Mods Done
      1991 Lumina Z34
      3.4 DOHC
      Getrag 284 5spd
      1 of 30
        • 13534
        id say 210-220 whp but it depends on the dyno and how good that tune really is:P Get me some AF ratios and the dyno results and I can probably tweak it from there for you.
        • 1995gtpGPdohc
          • Feb 2007
          • 10
          I thought that the 3.4 engine was supposed to have 215 horses stock, is that at the crank, or have I been reading wrong info on several other web sites?
          http://www.cardomain.com/ride/2504648
          • grandprixgtp_91
            • Nov 2003
            • 758
            ok ill get as much as i can get. my 3.4L has 210 hp stock at te crank, the 5 speed motor has 10 hp more, we are talking about wheel hp here, its always lower. Ben what is 210-220 whp roughly in crank hp? i dont know how to calculate the crank hp from the wheels.
            Jake
            • OldSkoolGP
              That guy over there
              • 930
              That's pretty much my old setup verbatim, except I have Borla Pro XS mufflers and no cat. I made 212.6 WHP and 216 WTQ.
                • 13534
                Shh! Thats how I came up with my guess:P
                ~15% loss from the manual trans, supposedly. I don't know for sure what that is crank off the top of my head.
                • grandprixgtp_91
                  • Nov 2003
                  • 758
                  ok i dynoed it today, something is jacked up with the dyno though, first vehicle that we tested was a 95 gmc sierra with a 350 with quite a bit of work done to it and it dynoed 121 hp at the wheels and 478ft.lbs/tq??? that doesnt make any sense. so then i ran mine on the dyno and mine had 151hp and 448 ft. lbs/tq ???? once again makes no sense. my car was just smoking the tires off on the dyno, as soon as i shifted through the gears and got the go ahead to stomp it, i let her rip and the tries started smoking and throwing rubber chunks off my $1000 tires , it nailed the redline and the tires had to catch up. then the dyno operator says, " well those numbers arnt right" he said its because its set up for diesel trucks. so there gonna try and set it up for fwd v6 cars. he said if he can than it will work alot better, i guess being set up for a diesel just made it read totally wrong
                  Jake
                    • 13534
                    No, that sounds right. j/k. wtf is up with the dyno operator? Setup for a diesel? Smoking your tires on the dyno? I honestly wouldn't put my car back on there after all that.
                    • grandprixgtp_91
                      • Nov 2003
                      • 758
                      yeah i was pretty pissed , but there are no other dynos in the area, so maybe if he can get it set up right then ill put it back on.
                      Jake
                      • timg
                        • Feb 2004
                        • 718
                        Hmm... That sounds a bit shady. I managed to put down over 400 whp on snow tires on a Dynojet with minimal slippage. On Dyno Dynamics dynos, people routinely dyno 1000 whp cars with no wheel slippage.
                        Did he have the RPM pickup setup correctly? Check his RPM readout. I'll bet it's off by at least 50%.
                        Tim
                        325 whp 350 lb-ft
                        • grandprixgtp_91
                          • Nov 2003
                          • 758
                          yeah ill have to check things out, i mean it was just destroying the tires, the car was strapped down tight and when it was time for a reading, it just spun them, alot, it was very bad.lol
                          Jake
                          • z34phoenix
                            • Jun 2005
                            • 469
                            sounds to me that it had too heavy of a drum or the dyno brake was one or something. you tires should not have been spinning. but 478lbs of Tq are nice #'s lol should post that up! most tq NA!!! yeah i really want to see your #'s cause short of your ported heads, your setup is close to my monte.
