Before I go any further (DOHC rebuild)
  • StEvEzAsYcHo
    • Jul 2004
    • 145
    I have a 96 DOHC I am building as you all know. I am buying a Cutty vert w/ a Turbo setup.. I intend to keep the vert stock for driving around in the summer and such.. If I remember correctly, the 91-5 LQ1s have a lower compression ratio thant the 96-7.. I have my 96 heads and intakes, etc.. SO I can use those..
    ..WHAT gives these motors the lower compression ratio? (If I am remembering right).. Would I be better off turboing the lower compression ratio LQ1? I am stuck rebuilding my 96 because I cant get a grip on the crank pulley and sprocket to remove everything else in there to get it cleaned in honed..
    ..I just want to make sure I am using the best block for what I want to do.. Thanks for helping me out with all my noobness on rebuilding the DOHC!!
    90 Chevy Lumina: 3.1L V6; swapping out for TLQ1
    94 Cutty Supreme: 3100 V6
    Soon: Something new?
    • 13531
    I don't know that either would be too high compression to boost. Use the 96 motor and keep 9.7:1. The heads give the bump in compression for 96/97, but im not sure what the piston difference is in cc's.
    • StEvEzAsYcHo
      • Jul 2004
      • 145
      I know the pistons are different for 96-7, but I do not know the difference, lol..
      I just wanted to make sure I have the right block/motor for the job.. I'll stick to my 96 and get the damn thing apart finally and get it ready to go..
      • 5spdGtp
        • May 2006
        • 45
        i thought the blocks were the same but the internals were differnt. differnt heads and pistons in the 96 is what gave it more compression. but i might just be severly misinformed!
        • heza
          • Apr 2004
          • 96
          whos cutty vert turbo did you buy? is it white and came from a certain someone in burnsville?
          • StEvEzAsYcHo
            • Jul 2004
            • 145
            Correction: Woho's white Cutty vert w/ turbo pieces AM I buying. I need to seel an Achieva first to make room in my small stable.
            I need a new DOHC though. Mine is Fubared. THe cylinder is completely destroyed for #3 on mine. I am just going to push it to the side, and get a strong running DOHC to toss in the car because this has taken far too long to finish. I'm pissed about it though.. I still have the heads and intakes for the 96, and will use those parts on the new one (Should it happen to be a 91-95).
            Look for a thread in a couple minutes.
