what happen !!!
  • tijuana_no
    • Aug 2005
    • 261
    what happen !!!
    i keep forgetting to post this pic's ,but check'em out and see if you can tell me what happen.
    this engine had about 90,000 miles very well keep ,maintaine by gm techs i had gm extended warranty and had a new belt at 70,000 miles and a tune up just before it happen. i 'am telling you this to see if help determine what happen.
    i just love to watch the wheels turn around and around
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    well i can definatly see the problem lol
    not familliar with dohc, but maybe its a belt tension issue ?
    is that one gear upper right, saposed to look like its more out ?
    warped head maybe ?
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      holy crap!!!
      at least it was caught be4 the belt broke but it also looks like the pulley in the middle is crooked.
        • 13534
        no, its just the angle making it look crooked. Belt tensioner/pulley setup maybe, but its hard to tell since that is all rusted now and who knows the condition when it was fresh.
        • Schurkey
          • Apr 2007
          • 339
          I don't know what happened, but mine did the same thing--tore off the outer 3/8" of the belt in ~20K miles.
          The dealership charged me full price to re-do their mistake. And I was stupid enough to let them.
          From now on, I'll do my own timing belts using the full timing belt kit (belt and three pulleys)
          • tijuana_no
            • Aug 2005
            • 261
            how did your engine acted when this happen.
            i lost power and i think i mess up something on the back 3 cylinder.i'll be tearing it apart latter.
            • Schurkey
              • Apr 2007
              • 339
              Mine ran fine. Went to the dealer because the alternator died; they pulled the timing belt cover at the upper front and showed me the timing belt was all chewed up.
              So I wound up with both a timing belt job; and the alternator.
              • Juglenaut
                • 1130
                To me the tension was not set right, or they didn't make sure the belt was set right before actually starting the engine. Looks as if they also failed to rotate the engine manually several times to verify.
                I am leaning towards a tensioner problem.
                I am back
                Mechanical/Service Technican
                • Fierobsessed
                  • Mar 2004
                  • 219
                  Im jumping on the tension bandwaggon, but I have to say, where the hell is the boot on the tensioner assembly? The reson I think the tension wasn't set properly is by looking at the position of the square nub on the tensioner pulley, I usually expect to see it at a 4 o'clock position, as opposed to a 5-6 o'clock.
                  Like others have said, if the idlers bearings go the belt will walk out like that.
                  Is poor servicing of the belt that caused it. I mean, a missing boot on the tensioner is a pretty stupid and blatant mistake made by the technician, let alone the fact that they probably never gave the tensioner pulley the little tug it needs to set proper tension on the belt, and if it was the idlers, they should have been replaced with the belt anyway.
                  • tijuana_no
                    • Aug 2005
                    • 261
                    but,why did i lost power and lost compression on 3 cylinder on the back by the firewall.you guys think i mess something inthe engine also.
                    • 94GPGTP
                      95 Grand Prix GTP
                      • Apr 2007
                      • 593
                      maybe you jumped timing and its not creating compression at the right time.
                      Robert
                      New Rebuilt 3100
                      New Rebuilt 4T60-E
                      Exhaust
                      Drilled/Slotted Rotors
                      White
                      3" Magnaflow Catback
                      90 Pontiac Turbo Grand Prix
                      5 Speed Swapped
                      127,000
                      Spec Stage 3 Clutch
                      230,000 mile Getrag 282
                      Emissions Deleted
                      Brand new Engine 1,000 Miles
                      Fully Custom Built car
