Next best sparkplug?
  • bve32k
    3.4 DOHC FTW
    • Jun 2005
    • 475
    Ok. Here is what I have done. I have a 96 3.4L DOHC engine with the 60DegreeV6 Valve springs, retainers, light weight lifters, 8.5MM Magnecor Wires. I can't think of anything else, but I am sure I have more I should be putting up.
    But I have tried the AcDelco RapidFire 6's and 12's. The 12's I went through within 2,000 miles. The engine was jumping around badly. I have been running the 6's for about 2,000 miles and now the engine is starting to jump around again.
    Is there another plug I should try or is there something wrong?
    Edit: The 12's I found out were gapped @ .060 and the 6's I have are gapped @ .045.
    Here is a pic I took of the 12's. I haven't taken out the 6's yet. Top left one is piston #1 and bottom right one is piston #6. You guys catch the drift.
  • pwmin
    • Aug 2004
    • 394
    how bout just getting some regular R42LTSM plugs and gapping them at 45?
    91 GTP HM-284 GONE :(
    98 Spawn of Satan (L67 Regal)
    87 V10 SM-465/Mild 350
    06 Cobalt SS/SC GONE :(
    • bve32k
      3.4 DOHC FTW
      • Jun 2005
      • 475
      That was my next option. I just didn't do it yet because I wanted to get other peoples opinions first.
      • z34phoenix
        • Jun 2005
        • 469
        the middle ones have the electrode burned away much more...
        i would have your ICM checked and also test the resistances of all three coil packs... then make sure you use dielectric greese...
        then i would check your grounds at the pcm and bat to frame.
        something is causing the spark to be too hot. or there is a issue such as detonation that is destroying the tips.... if your ever in the daytona beach area let me know and i can give you a quick PCM tune, but deff get something to scan for KR... chances are you have some... i have noticed most of the plugs i have pulled from 96-97 DOHC's show lean.
        • bve32k
          3.4 DOHC FTW
          • Jun 2005
          • 475
          Thanks! But the computer is OBD1.5. Still have the 95 computer in my car. I checked the resistance on all the coils and I replaced the ICM. Everything seems normal.
          • Rhedalert
            Dr. Feelgood
            • 1574
            Does NGK Make something for your motor? They've been great in my Camaro (lot of LS1 guys use them) just the basic resistor plugs. I'm going to throw a set in my Olds too.
            Brian
            3400 SFI V6, 4T60e
            • HayesPerformance
              • 783
              Stick to the factory plugs and make sure they are gaped perfectly the same.
              I have tried other plugs and this engine Doesn't run well on too many others.
              1991 Grand Prix STE
              3.4 DOHC
              1 of 792 Produced
              Extensive Mods Done
              1991 Lumina Z34
              3.4 DOHC
              Getrag 284 5spd
              1 of 30
              • HayesPerformance
                • 783
                Oh ya,
                DO NOT INSTALL THE BOSCH PLATINUMS IN YOUR GM ENGINE!!!
                1991 Grand Prix STE
                3.4 DOHC
                1 of 792 Produced
                Extensive Mods Done
                1991 Lumina Z34
                3.4 DOHC
                Getrag 284 5spd
                1 of 30
                • RedZMonte
                  • Feb 2004
                  • 1378
                  Stock delco's or NGKs will both be good plugs.
                  Shane "RedZMonte"
                  1992 Lumina Z34-VIRGIN (RIP)
                  1992 L67 Lumina Z34 (SOLD)
                  1990 Turbo Grand Prix (SOLD)
                  • pwmin
                    • Aug 2004
                    • 394
                    i would just try some stockers and see if the problem is still there. theyre cheap enough to replace. may just be a problem with the platinum. btw, i have 5 decent used 12s you can have if you want them.
                    • bve32k
                      3.4 DOHC FTW
                      • Jun 2005
                      • 475
                      I had 12's. But my engine seemed to have gone through them pretty fast. So I don't think I will be going back to them soon. I think I am going to try stockers or NGK. Not sure yet.
                      • torq455
                        If I only had money!!!
                        • 1615
                        how hot of a plug are the 6 and 12's? too hot of a heat range can melt the plugs.
                        Andy
                        fastest 1/8: 10.19@ 67.17
                        fastest 1/4: 16.16@ 82.70
                        • bve32k
                          3.4 DOHC FTW
                          • Jun 2005
                          • 475
                          I believe the 6's are cooler plug than the 12's. IIRC.
                          I haven't taken the 6's out yet. But I am about to switch to the standard copper core plugs. To see if they run better.
                          • HayesPerformance
                            • 783
                            The A/C plug for the 3.4 dohc is ACR42LTSM
                            In my GM Catalog when broken down means the following;
                            "A" - Clip style gap
                            "C" - Copper Core Center Electrode
                            "4" - 1st number denotes THREAD SIZE 4 = 14mm with 1/2" tapper
                            "2" - 2nd number denotes HEAT RANGE
                            COLD ------------- HOT
                            0-1-2-3-4-5-6-7-8-9
                            "L" - Long Reach
                            "T" - Tapered Seat Shell Design
                            "S" - Sport Vehicle (Only on 3.4 dohc)
                            "M" - Specially Designed Electrode
                            1991 Grand Prix STE
                            3.4 DOHC
                            1 of 792 Produced
                            Extensive Mods Done
                            1991 Lumina Z34
                            3.4 DOHC
                            Getrag 284 5spd
                            1 of 30
                            • garylau
                              • Aug 2007
                              • 57
                              Originally posted by HayesPerformance View Post
                              Oh ya,
                              Just curious, why is that? I think I recall using them a couple times.
