Car runs like crap
  • bve32k
    3.4 DOHC FTW
    • Jun 2005
    • 475
    Car runs like crap
    Any idea's anyone?
    I still have no acceleration! The car is balls less period! I don't know what to do anymore!
    I replaced IGN Module, Coils, Plugs, Fuel Injectors, Fuel tank, fuel pump, fuel filter.
    It is not popping up any codes. Only code that comes up is AIR Injection System because I don't have it on my car and I did OBDII swap.
    But I was dealing with poor acceleration even before OBDII swap.
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Exhaust, the CAT is plugged.
      Put this on your car if you want balls ^^
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        I think he'd be better off with these...
        Adjust your powerband
        DUAL o pipe!
        and a BAR OF BOOST!
        • bve32k
          3.4 DOHC FTW
          • Jun 2005
          • 475
          What are the symptoms of a clogged Cat?
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Hard start, rough idle, really hot engine/exhaust temps. There's a few more, I just have a brain fart right now.
            • 94GPGTP
              95 Grand Prix GTP
              • Apr 2007
              • 593
              the egr will chatter too from the exhaust pressure..
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              Drilled/Slotted Rotors
              White
              3" Magnaflow Catback
              90 Pontiac Turbo Grand Prix
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              230,000 mile Getrag 282
              Emissions Deleted
              Brand new Engine 1,000 Miles
              Fully Custom Built car
                Sluggish car with no power as well, like it's being choked and can't breath because, well, it is.
                • bve32k
                  3.4 DOHC FTW
                  • Jun 2005
                  • 475
                  Here is a WOT from a dead stop.
                  I think I am going to take the air filter off today to see if it runs any better because the air filter is pretty dirty. I may have another one laying around somewhere. I am pretty broke right now so can't buy a new one.
                  Here is another video of first starting the car. Then at the end you can see the exhaust shaking. Kind of hard to see it in the video.
                  • d.o.h.c
                    • Jun 2004
                    • 981
                    Humm might be the problem with my car. I have never cleaned it,lol. I will try.
                    M
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      Hows your timing? Might be retarded too much?
                      • d.o.h.c
                        • Jun 2004
                        • 981
                        seemed to fix my problem, yeahhh. Well see if I get a code in a couple days.
                        • bve32k
                          3.4 DOHC FTW
                          • Jun 2005
                          • 475
                          Mine still seems to be the same.
                          What is your IGN Adv Degree's at idle?
                          • d.o.h.c
                            • Jun 2004
                            • 981
                            I have no idea, I had shane (redzmonte) tune it.
                            • d.o.h.c
                              • Jun 2004
                              • 981
                              Haha, I got a p0336. What crank sensor is that? I think that Gm forgot to connect it when they did the oil pan the other day. Please let me know so i can fix this tonight.
                              m
