Car runs like crap
  • bve32k
    3.4 DOHC FTW
    • Jun 2005
    • 475
    Originally posted by d.o.h.c View Post
    Haha, I got a p0336. What crank sensor is that? I think that Gm forgot to connect it when they did the oil pan the other day. Please let me know so i can fix this tonight.
    m
    I thought you had the Actron scanner cause you can view that with the actron scanner.
    It is the 24x sensor but I can't figure out which one it is. It is either the one on the top on the cam carrier or the one down by the harmonic balancer.
    • d.o.h.c
      • Jun 2004
      • 981
      Yeah I have the scanner it just tells me 336 crank position sensor a low performance. I checked and I have voltage to the sensor. I just had my oil pan serviced, I bet you thats it. Hope I can get home.
      • bve32k
        3.4 DOHC FTW
        • Jun 2005
        • 475
        The Actron scanner tells you the IGN ADV (degree) info under view data.
        • d.o.h.c
          • Jun 2004
          • 981
          Yeah why would I need to know that?
          • d.o.h.c
            • Jun 2004
            • 981
            Deffinietly broken wires on the crank sensor, could that cause 171 code
            • bve32k
              3.4 DOHC FTW
              • Jun 2005
              • 475
              #21
              I wanted to know what yours is because mine seems to be wrong! Or like way off!
              • d.o.h.c
                • Jun 2004
                • 981
                #22
                oh lol. When I scan the car again I will let you know. My car did seem to run much better with the filter off. I think that it was just coincidence that the wires rubed through just enough to cause a problem.
                • SuzukiGhostRider
                  Beretta Freak
                  • Apr 2008
                  • 118
                  #23
                  Might just be me here BVE, but that car sounds like it's missing badly in the second vid clip! I'm going to venture a guess that your timing belt slipped a tooth. I really think you need to replace your timing belt. GL.
                  • bve32k
                    3.4 DOHC FTW
                    • Jun 2005
                    • 475
                    #24
                    I may have to go buy a new timing belt and re-time the engine.
                    • bve32k
                      3.4 DOHC FTW
                      • Jun 2005
                      • 475
                      #25
                      Ok. I was playing around with the car yesterday and I am not sure where this wire goes. I plugged it into my PSP because it was the same exact plug and it was right there. Apparently the plug does not go there! I was checking out some Monte Carlo pics and the plug plugs into something on the passanger side. But I have no clue what it is. Anybody have any idea's? When I unplug the plug from the PSP then it throws a code P1200 which is Injector Control Circuit.
                      I am confused as to where this wire goes.
                        I don't have that plug on my car but if it's the one I am thinking of it would be the canister purge solenoid. Is the plug red?
                        • d.o.h.c
                          • Jun 2004
                          • 981
                          #27
                          OK, my car is running great again, hopefully it stays that way. BV-you want me to get you that info from my scanner? What do you want and do you want the car on, running or driving?
                          • bve32k
                            3.4 DOHC FTW
                            • Jun 2005
                            • 475
                            #28
                            The canister purge solenoid is already plugged in and so it the flow sensor for the EVAP.
                            I would still like to know what #'s you are getting for it while you are idling.
                            • d.o.h.c
                              • Jun 2004
                              • 981
                              #29
                              will do, I can do it tonight.
                                I mentioned it because I thought someone before had noticed it was the same type/color plug for the steering assist deal and the purge solenoid, therefore could easily be mixed up.
