Found a black 92 GTP at the local pick n pull
  • GTP091
    • Jun 2005
    • 232
    Looks like it had a minor front end crunch, rad is pushed in about an inch. Engine should be good but the timing belt was heavily frayed. Has a 40t60e and the LQ1; was hoping for a 284. Already missing the maf, iac valve and front valve cover (me). The body panels are no good. Has dark leather seats but are in rough shape. Possibly going back on thursday or friday so if any one needs some parts I can check it out.
  • 5speedz34
    • 301
    MAF sensor?
    • gpchris
      • Feb 2007
      • 477
      where do you live?
      • GTP091
        • Jun 2005
        • 232
        Originally posted by 5speedz34 View Post
        MAF sensor?
        MAF Sensor was gone when I got there. and the IAC valve. I pulled the front cam carrier cover off and it's currently getting powder coated. Tried to pull the main rad fan but it had a bearing squeak so I left it. Got a few trim pieces. The GTP badges were also gone.
        • GTP091
          • Jun 2005
          • 232
          Originally posted by gpchris View Post
          where do you live?
          Kelowna BC.
          • 5speedz34
            • 301
            What I meant is the 91-93 car's never got a MAF. They had a MAP.
            • GTP091
              • Jun 2005
              • 232
              my bad, I meant MAP, either way it's gone.
              • webxfx
                • Oct 2008
                • 8
                Quad Buckets?
                • GTP091
                  • Jun 2005
                  • 232
                  Originally posted by webxfx View Post
                  Quad Buckets?
                  It has quad bucket seats but they are leather and need to be recovered.
                  • webxfx
                    • Oct 2008
                    • 8
                    what color any ways? want to guess Brown...
                    I guess I'll just keep watching localy
                    • GTP091
                      • Jun 2005
                      • 232
                      Went back today and pulled the HUD out for $9.99. The seats are charcoal grey; some dick pulled the rear seat and cut squares out of the flat parts in all the other seats to get the leather.
                      • dohcfiend
                        King Chalupa
                        • Jan 2004
                        • 2351
                        what color carpet is in it? what color front seatbelts?
                        • GTP091
                          • Jun 2005
                          • 232
                          Dark gray seatbelts, dark grey carpet (charcoal)
                          • dohcfiend
                            King Chalupa
                            • Jan 2004
                            • 2351
                            i'll upload a pic or 2 over the weekend and if it matches the interior in them, can you pull a few interior parts for me? i'll re-imburse you for labor.
                            most are easy.
                            1. one of the little coat rack fingers in the back of the car
                            2. both of the little ashtrays for the back if you cen get them out without breaking the tabs
                            3. the passenger (or driver) side plastic thingy for the seatbelt. it is where the seatbelt meets the doorpanel, it is plastic, and is held in by 2 phillips screws
                            4. the carpet
                            5. both front seatbelts plus you have to tell me how to remove them b/c i do not know.
                            • GTP091
                              • Jun 2005
                              • 232
                              No worries on the labor it only takes a minute to pull this stuff
                              I already pulled the seat belt covers thinking mine were scratched they weren't and either were these.
                              I can get the ashtrays out for sure another GP showed up so two out four should be good.
                              The carpet is heavily soiled so I don't think you would want it, but I'll look again
                              I didn't see what condition the seat belts are in, but I can look. My light gray belts were quite dirty but I restored them with oxy clean, the look new again. The belts are easy to take off but you have to pull the door panel.
