Oil filter relocation
  • Lyle's GTP
    • Jan 2004
    • 1345
    Does anybody know a good oil filter relocator kit for our cars? Also, what size of an oil filter should I use? Also where can I buy it in canada?
    Lyle
  • Anonymous
    Why?
    It is going to be hard to relocate becuz the 3.4 DOHC has a factory oil cooler, this is in between the block and the filter and has a couple of rubber coolant lines running around ti as the oil cooler uses the engine coolant.
    • jmgtp
      • 1219
      Originally posted by Aaron
      Why?
      I don't have a factory oil cooler. I think only the auto trans cars got the oil cooler on the oil filter adapter.
      anyways....
      Why do you want to relocate the oil filter? I think its in a good spot. Easy to get at and not in danger of road debris. As far as filters, the Ac Delco PF52 is a good choice.
      1994 Corvette
      LT1/ZF6
      2006 Dodge Dakota 4x4
      3.7/42RLE
      • Mitch DOHC
        • Jan 2004
        • 261
        i also dont have tho oil cooler...... but i think they droped it in 94 dident they
        1994 Cutlass Supreme Convertible 3.4 DOHC
        1969 Oldsmobile 442
        1997 Chevy Tahoe
        http://members.cardomain.com/mperkins442
        • Anonymous
          Are you guys POSITIVE????
          Mine is a 5-speed, and not only did I have one but I bought one for my car. That is weird. It is hard to notice, it's just a small black canister, like the filter, but half the length, and it is as black as the motor.
            • 13533
            they dropped it in 94. all 91-93 have it. Relocating it would be nice since you could add a better cooler and a 2 filter setup Im not sure what size the filter is though, or where to get one. The pushrod guys might actually help you out since their filter is in the same spot and someone probably has done it.
            • jmgtp
              • 1219
              I never noticed any water lines running to the adapter on mine.
              1994 Corvette
              LT1/ZF6
              3.7/42RLE
              • Anonymous
                They look like heater hoses, but they carry antifreeze to and from the cooler.
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  No cooler on mine. Try this link, may help, they seem to make it easy. I used one on a 1970 Cougar 10 years ago.Their setups seem to cover just about everything. May have to search to find a dealer. They also don't list our applications, you may have to contact them. http://www.thinkauto.com/index.htm
                  • Lyle's GTP
                    • Jan 2004
                    • 1345
                    Hey, Ben. Help me out here. I never really considered two filters. This would definatily increase oil flow but would it also mean that I have to change my filters half as much? Plus, wise or not, if I used a good synthetic, theoreticaly I could do oil changes half as much as well.
                    Lyle
