why the 3.4 at all?
  • Teardrop
    • Sep 2010
    • 24
    why the 3.4 at all?
    The 3.4 NA produces right around 200 hp.
    The 3.8 NA produces right around 210 hp.
    3.4 - DOHC nightmare
    3.8 - single cam with chain.
    What exactly did GM think the benefit of using the 3.4 would be?
    As the 3.4 takes a mess of cams to come close (but still fall short) of the 3.8, what was it really worth?
    Not like the 3.4 is THAT much more gas efficient.
    Just trying to learn something here.
    1994 Grand Prix GTP 3.4 DOHC
  • 2.8-350TBI
    RWD FTW!!!
    • Sep 2009
    • 350
    Nightmare: Taking turns with a 3800 at high speed
    Nightmare: Changing the rear spark plugs on a 3800
    Nightmare: The tiny ports a 3800 has
    Nightmare: Changing the cam on a 3800
    Nightmare: Exhaust sound on a 3800
    Originally posted by Mars
    Haha ^ Wrong Wheel Drive.
    No 60ºV6 at the moment
      3.4 DOHC (94-97) 215 hp and 225 lb·ft
      3.8 (Series 2) 205 hp and 230 lb·ft
      Get your numbers straight
      BTW, 1.5 million 3800 equipped cars were recalled due to the leaking valve covers causing engine fires. How many 60v6 cars were recalled for the same thing? None
        • 13522
        Call GM.
        • mrl390
          • Jan 2008
          • 132
          Because my stock 3.4 will smoke a stock 3800 and doesnt sound like poop while doing it.
          /thread.
          -Matt
            this thread delivers.
            oh, and the L67 runs like ~7 or 8 PSI to make a whopping 240HP, right? the LQ1 at the same pressure ratio will make somewhere around 300HP.
            • Dave96z34
              • Apr 2005
              • 624
              Its more then 300 hp with the same boost numbers with the same blower.
                over 300?
                i guess i was a bit conservative then!
                • Dave96z34
                  • Apr 2005
                  • 624
                  Well then again i forgot to note with an intercooler...
                  • Schurkey
                    • Apr 2007
                    • 339
                    "Why the 3.4 at all?"
                    How about the simple answer:
                    "To compete with the Ford Taurus SHO having the Yamaha-designed and built DOHC V-6."
                    As supplied in stock form, the Yammie engine probably put out a few more ponies than the GM unit; and did it with less displacement (3.0L). The Japs definitely know how to build a powerful DOHC engine. Eventually, the Taurus SHO got a DOHC V-8 (but it had significant problems.)
                    The main problem with the Taurus SHO is that it was based on...the Taurus. What a shitbox.
